Update firmware issue X440G2
  • Problem
  • Updated 1 year ago
  • Solved
I downloaded the newest firmware image that is "recommended" for this switch which is 21.1.3.7patch1-4
When I attempt to upload the firmware via tftp it connects fine and tries to start pulling the file but then I get an error.
Downloading to switch..Error:Failed to download image - Error: FILE IS NOT PROPERLY FORMATTED.
Well, the file is 21.1.3.7-patch1-4_MIB.xos     I did download it originally from the extreme site as ".txt" and I just renamed its extension.  Was that not correct to do?  It won't upload as .txt as it doesn't see it as proper image.
Photo of Derek Mayberry
Derek Mayberry
  • 150 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
Hello Derek,
That file has MIB in it. Not sure how it ended up with a .xos at the end but there should be another file to download that comes with .xos.
Photo of Drew C.
Drew C., Community Manager
  • 40,218 Points 20k badge 2x thumb
Hi Derek, The MIB file is meant to be a text file - it's the MIB for use in an NMS. You need the actual summitX-21.1.3.7-patch1-4.xos file to install it.
I'd suggest getting patch1-7 instead. The recommended releases document isn't updated to show it yet. patch1-11 should be out soon too.
Photo of Tyler Edwards
Tyler Edwards, Employee
  • 250 Points 250 badge 2x thumb
Hello Derek,
The file you downloaded was the MIB file for that version of EXOS. It does not contain the image of the firmware.
The file you want to download is summitX-21.1.3.7-patch1-4.xos . It will have the ".xos" extension originally.
Regards,
Tyler Edwards
Derek Mayberry
Thanks guys.  I got the 21.1.3.7 patch 1-7 installed now and working fine.
Photo of Drew C.
  • 40,014 Points 20k badge 2x thumb
Welcome to The Hub, Derek!  Glad we could help.
