Updating the secondary firmware on Access Point from which is adapted to a controller ?
  • Question
  • Updated 3 months ago
  • Answered
Dear All,
Bonjour,
can anyone help me how to upgrade the secondary firmware of a Access Point which is connected over a controller and please suggest me the steps to follow and do the process at the earliest.
AP model :  AP7522 (5.8.6.5-002R  both primary and secondary Images)
Controller :  VX9000 (5.8.3.0-041R)
Is that any possibility to upgrade the firmware over console access. ? ()
Photo of Vimalraj Veerabathiran
  • 328 Points 250 badge 2x thumb
  • thankful
Posted 3 months ago
Photo of Timo
Timo
  • 2,786 Points 2k badge 2x thumb
you can update via CLI or GUI. Also update over the VX9000 is possible.
What version do you want to install, 5.8.3.?
Use via CLI "upgrade <PATH>". This updates the not running firmware bank. After you upgrade and reboot, you can do the same again. This updates the other firmware bank.
upgrade ?  FILE  Location of firmware image
               usb1:/path/file
  URL   Location of firmware image
        URLs:  tftp://<hostname|IP>[:port]/path...
                ftp://<user>:<passwd>@&lt...
                sftp://<user>:<passwd>@&l...
                http://<hostname|IP>[:port]/pat...
                cf:/path/file
                usb<n>:/path/file
Is it possible to upgrade firmware by Console access ?
Photo of Timo
Timo
Yes, same way. But you need to provide the firmware file via network.
Thanks. It works.
Photo of Richard Muehlberger
Richard Muehlberger
  • 170 Points 100 badge 2x thumb
hi
when connecting directly to the ap, use the commands Timo told you.
you have to provide the imge file for the ap ether by a server (ftp/tftp/...) or by uploading the image to the controller.
because the ap is connected to the controller i recommend this way.
also it is possible to update other aps later
as server i prefer ftp, works best for me till now.
for upgrading by controller, go to cli of the controller:
# device-upgrade load-image ftp://<user>:<password>@&...
check the upload state with
# show device-upgrade load-status
# show device-uprade version
when image is on the controller you can use the device-upgrade command
# device-upgrade XXXX
pls use "?" to choose the right option for the update
check the upgrade of the ap with
#show device-upgrade status
nr
richi
Photo of Christoph S.
Christoph S., Employee
  • 2,284 Points 2k badge 2x thumb
