Upgrade EXOS 16.2 for BD 8800 MSM-48c
  • Question
  • Updated 2 years ago
  • Answered
Hi expert,
We are going to upgrade EXOS from release 15.3.2.11 to 16.2.1. Current HW is BD 8800 MSM-48c.
Please advise if release EXOS 16.2.1 does support current HW MSM-48c? And anyone already do upgrade it? please share your experience
Thanks!
Photo of Luc Tran
Luc Tran
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of David Choi
David Choi, Employee
  • 1,968 Points 1k badge 2x thumb
Hi Luc,
When I look at release note of 16.2.1.6 version, limitations for MSM-48c are specified.
I believe that implies the version is supported on MSM-48c.
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
The version you are going to use is supported and I run it on my chassis currently.  Since you are already running 15.3 all of the blades you have will be supported too.  Just check the reference to confirm:  http://www.extremenetworks.com/extreme-hardwaresoftware-compatibility-recommendation-matrices/extrem...
Other then that you are good to go.
Photo of Drew C.
Drew C., Community Manager
  • 40,690 Points 20k badge 2x thumb
Hi Luc, Welcome to The Hub!
I've made this conversation "public" since it doesn't contain any private information.
Photo of Luc Tran
Luc Tran
Hi all,
Thanks for your prompt respond. It is ok that EXOS 16.2 support HW MSM-48c. However, customer raise a question that the ExtremeXOS Release Recommendations for BD 8800-MSM48c is EXOS 16.1.3.6-patch1-9.
http://www.extremenetworks.com/extreme-hardwaresoftware-compatibility-recommendation-matrices/softwa...
Can you help to advise to communicate with customer?
Thanks!
Photo of Henrique
Henrique, Employee
  • 10,342 Points 10k badge 2x thumb
Hi Luc,
The recommended EXOS version for MSM-48c is EXOS 16.1.3.6-patch1-9. However, there is a new patch (1-11) and an EXOS version 16.1.4 with some important fixes. I would recommend you to review the Release Notes for further information regarding all the fixes. You can access the Release Notes in the link below:
http://www.extremenetworks.com/support/release-notes/
Also, please make sure the BD8k I/O cards also support that new release. That's really important.
Photo of David Choi
Hi Luc,
The recommendation page is updated by 3 month period. And I could see the last update was 15 Sep as below:
To be sure the exact recommended version of now, it would be better to ask GTAC after creating case.
