Uplink port capabilities on Stacks
  • Question
  • Updated 3 years ago
  • Answered
I need to find out the port (speed) capabilities for some stacks. Is it possible through EXOS?
The goal is to know, which speed is maximum supported on the uplinkports. i dont need to know which SFP is currently insert.
If there is no similar command to Ciscos "show port capabilities", how can i get the model of each Stack member?
Photo of holden
holden
  • 452 Points 250 badge 2x thumb
  • confused
Posted 3 years ago
Photo of Alexandr P
Alexandr P, Embassador
  • 12,768 Points 10k badge 2x thumb
Hi, Holger!
There is a lot of command for to see what type of switch is stack member
My favorite is #show odometers
#show odometers                                              Service  First Recorded
Field Replaceable Units                 Days     Start Date
Slot-1         : X670V-48x                  337
Slot-2         : X670V-48x                  335
Photo of Drew C.
Drew C., Community Manager
  • 40,858 Points 20k badge 2x thumb
Hi Holger, Try this command:
Slot-1 Stack.7 # show stacking stack-ports
Stack Topology is a Ring
Slot Port Select Node MAC Address  Port State  Flags Speed
*1   1    Native 00:04:96:99:6d:dc Operational CB      21G
*1   2    Native 00:04:96:99:6d:dc Operational C-      21G
 2   1    Native 00:04:96:99:99:9d Operational C-      21G
 2   2    Native 00:04:96:99:99:9d Operational CB      21G
* - Indicates this node
Flags:  (C) Control path is active, (B) Port is Blocked
(Edited)
Photo of Drew C.
For port capabilities, this may be helpful:
X460G2-24t-G4.1 # show ports configuration no-refresh
Port Configuration
Port Virtual Port Link Auto Speed Duplex Flow Load Media
router State State Neg Cfg Actual Cfg Actual Cntrl Master Pri Red
1 VR-Default D R ON AUTO AUTO UTP
2 VR-Default D R ON AUTO AUTO UTP
3 VR-Default D R ON AUTO AUTO UTP
30 VR-Default D R ON AUTO AUTO NONE
31 VR-Default D R ON AUTO AUTO NONE
32 VR-Default D R ON AUTO AUTO NONE
33 VR-Default D R OFF 10000 FULL SF+_SR
34 VR-Default D R OFF 10000 FULL NONE
> indicates Port Display Name truncated past 8 characters
Link State: A-Active, R-Ready, NP-Port Not Present, L-Loopback
Port State: D-Disabled,E-Enabled, Media: %-Licensed, !-Unsupported, $-Restricted
Media Red: * - use "show port info detail" for redundant media type
Flow Cntrl: Shows link partner's abilities. NONE if Auto Neg is OFF
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,628 Points 10k badge 2x thumb
Also, if you are just trying to get port capabilities for one slot of the stack, you can specify the slot number with a wildcard for the port. See the example below for slot 2.
Slot-1 Extreme.4 # show port 2:* configuration no-refresh
Port Configuration
2:1      VR-Default  E      A    ON  AUTO  1000 AUTO FULL   NONE   1:1  UTP
2:2      VR-Default  E      R    ON  AUTO       AUTO                    UTP
2:3      VR-Default  E      R    ON  AUTO       AUTO                    UTP
2:49     VR-Default  E      R   OFF 10000       FULL                    NONE
2:50     VR-Default  E      R   OFF 10000       FULL                    NONE
2:51     VR-Default  E      R   OFF 10000       FULL                    NONE
2:52     VR-Default  E      R   OFF 10000       FULL                    NONE
(Edited)
Photo of holden
holden
Thanks.....
i suggest that the output of show ports configuration no-refresh only shows the current speed(current insert SFP), but not the maximal port speed which is provided by the switch.
Is this right?
(Edited)
Photo of Drew C.
  • 40,724 Points 20k badge 2x thumb
That's correct.
Photo of Drew C.
I've asked one of our developers to let me know if he comes across an easy-to-access data structure that contains this information.  At first pass, it looks like port capabilities are stored in such a way that we can't easily retrieve them with python scripting.  I'll update the thread if there's anything new to share.
(Edited)
