Uplinks are shown as blocked in VLANs + EAPS configured XOS switch
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
This is newly configured switch which will be connected to the production network. Before it I have to be sure about one thing. I have set up below EAPS config and VLANs. And still uplinks 1:52 and 2:53 are not connected (other nodes of the EAPS ring is already configured in live network).
My question is when I check the show vlan ..... , uplinks are shown as blocked.  Is this because of device is not connected  via uplinks? or some other reason ?
# Module eaps
configuration.
enable eaps
create eaps eaps10_8_2
configure eaps eaps10_8_2 mode master
configure eaps eaps10_8_2 primary port 1:52
configure eaps eaps10_8_2 secondary port 2:52
enable eaps eaps10_8_2
configure eaps eaps10_8_2 add protected vlan Vlan10_1
configure eaps eaps10_8_2 add protected vlan Vlan10_11
configure eaps eaps10_8_2 add protected vlan Vlan10_8_2
configure eaps eaps10_8_2 add protected vlan Vlan10_11_2
configure eaps eaps10_8_2 add control vlan eaps10_8_2_control
  # show eaps
EAPS Enabled: Yes
EAPS Fast-Convergence: Off
EAPS Display Config Warnings: On
EAPS Multicast Add Ring Ports: Off
EAPS Multicast Send IGMP and MLD Query: On
EAPS Multicast Temporary Flooding: Off
EAPS Multicast Temporary Flooding Duration: 15 sec
Number of EAPS instances: 1
# EAPS domain configuration :
Domain         State           Mo  En  Pri    Sec    Control-Vlan VID   Count Prio
eaps10_8_2     Failed          M   Y    1:52   2:52  eaps10_8_2_control (91  ) 4     N
Flags : (!) CFM Down
 # show vlan
Name            VID  Protocol Addr       Flags                         Proto  Ports  Virtual
        Active router
        /Total
Default         1    ------------------------------------------------- ANY    0 /0   VR-Default
eaps10_8_2_control 91   --------------------------------------C---------- ANY    0 /2   VR-Default
Mgmt            4095 ------------------------------------------------- ANY    0 /1   VR-Mgmt
Vlan10_1        2    10.2.20.1      /16  ------------------P---------- ANY    0 /2   VR-Default
Vlan10_11       12   --------------------------------------P---------- ANY    0 /10  VR-Default
Vlan10_11_2     112  --------------------------------------P---------- ANY    0 /10  VR-Default
Vlan10_8_2      10   --------------------------------------P---------- ANY    0 /187 VR-Default
Photo of Weda
Weda
  • 994 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hello Weda,
I quickly replicated this and see the same results. I would assume it is because there are no active uplinks so it is blocking the ports in the protected VLANs.
Photo of Weda
Weda
thank you very much
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
When you configure EAPS protected vlan and the ports are in "Ready" state and you enable both EAPS globally and the domain, it appears as "Blocked".
If you disable the respective eaps domain (disable eaps eaps10_8_2) you should see the "b" flag removed from the ports in the protected vlan.
That's an expected behavior.
Photo of Weda
Weda
thank you very much
