UPM Help
  • Question
  • Updated 5 years ago
  • Answered
Trying to configure a UPM profile for multiple devices based on device_detect. However not having much luck. Example below:
 IF ($MATCH($(EVENT.NAME) , DEVICE-DETECT) ==0 ) then
IF ($MATCH ($(EVENT.DEVICE_MODEL) , AP8132) == 0) then
Configure vlan vl-wifi-cntrl add port $EVENT.USER_PORT
Configure vlan vl-wifi-01 add port $EVENT.USER_PORT tagged
 If you EVENT.DEVICE_MODEL is AP8131 how do we also include other models as well? AP6511 and AP8131 for example?
Thanks in advance.
Mark
Photo of Mark Bayliss
Mark Bayliss
  • 100 Points 100 badge 2x thumb
Posted 5 years ago
Photo of Rex
Rex, Employee
This is what I have tested before. Different model of AP add to different VLAN.
if (!$match($EVENT.NAME,DEVICE-DETECT)) then
if (!$match($EVENT.DEVICE_MODEL,AP4511)) then
create log entry "ADD port $(EVENT.USER_PORT) to VLAN AP4511_1"
configure AP4511_1 add port $EVENT.USER_PORT
endif
if (!$match($EVENT.DEVICE_MODEL,AP4532)) then
create log entry "ADD port $(EVENT.USER_PORT) to VLAN AP4532_1"
configure AP4532_1 add port $EVENT.USER_PORT
endif
endif
if (!$match($EVENT.NAME,DEVICE-UNDETECT)) then
create log entry "AP is moved from port $(EVENT.USER_PORT)."
set var cli.out 0
show port $EVENT.USER_PORT information detail
set var baselist $tcl(split ${cli.out} "\n")
set var indexvalue $tcl(lsearch -glob $baselist *Name*)
set var vname $tcl(lindex $baselist $indexvalue)
set var vname $tcl(split $vname " ")
set var vname $tcl(lindex $vname 2)
set var vname $tcl(string range $vname 0 end-1)
config vlan $vname del port $EVENT.USER_PORT
endif
