UPM script to backup switch configuration and policies etc
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Jan 4 2012 4:15AM
Hi!
Enclosed is a UPM script we've been using for a while to backup XOS switches. We've used it on 450/460/BD10K etc. I think I'll require XOS 12.4.
It backs up the current config both as text and xml. It also backs up other files like .pol or .xsf. The files are stored on a tftp server, in a separate directory for each day (you have to create the directory structure with a script on the tftp server - included below). In our setup the the tftp root for the backups is /data/tftpboot/switchbackup/
Date and switch name are prepended to each file name (eg a123a-2012-01-03.cfg and a123a-2012-01-03.txt for XML and text versions).
We use the script to backup files to two different tftp servers - you'll have to enter your own ip address(es).
The script tries to intelligently decide to use the correct VR for the tftp command (vr-default or vr-management).
The script is first run 12 hours after reboot and then every 24 hours.
UPM SCRIPT:
create upm profile backup-config
configure cli mode scripting abort-on-error
set var CLI.OUT 0
set var tftproot switchbackup
show iproute vr vr-mgmt
set var input $TCL(split ${CLI.OUT} "
set var x $TCL(lsearch -glob $input "*Total number of routes = 0*")
if ($x == -1) then
set var vr "vr-mgmt"
else
set var vr "vr-default"
endif
set var seconds $TCL(clock seconds)
set var date $TCL(clock format $seconds -format {%Y-%m-%d})
show switch
set var x $TCL(lsearch -glob $input "*SysName*")
set var x $TCL(lindex $input $x)
set var x $TCL(split $x " ")
set var switchname $TCL(lindex ${x} 10)
set var x $TCL(lsearch -glob $input "*Config Selected*")
set var y $TCL(lsearch -glob $x "*.cfg*")
set var config $TCL(lindex ${x} $y)
save configuration
configure cli mode scripting ignore-error
tftp put 10.1.1.120 vr $vr $(config) $(tftproot)/$(date)/$(switchname)-$(date).cfg
tftp put 10.1.1.130 vr $vr $(config) $(tftproot)/$(date)/$(switchname)-$(date).cfg
upload configuration 10.1.1.120 $(tftproot)/$(date)/$(switchname)-$(date).txt vr $vr
upload configuration 10.1.1.130 $(tftproot)/$(date)/$(switchname)-$(date).txt vr $vr
ls
set var files $TCL(split ${CLI.OUT} "
set var n $TCL(llength $files)
set var n $TCL(expr {$n-5})
set var files $TCL(lrange $files 0 $n)
while ($n != -1) do
set var line $TCL(lindex $files $n)
set var filename $TCL(lindex $line end)
set var exempt $TCL(list license.xlic vmt)
set var suffix $TCL(string match "*cfg" $line)
if ($suffix == 0) then
set var dobackup $TCL(lsearch $exempt $filename)
if ($dobackup == -1) then
tftp put 10.1.1.120 vr $vr $(filename) $(tftproot)/$(date)/$(switchname)-$(date)_$(filename)
tftp put 10.1.1.130 vr $vr $(filename) $(tftproot)/$(date)/$(switchname)-$(date)_$(filename)
endif
endif
set var n ($n-1)
endwhile
UPM CONFIG:
configure upm profile backup-config maximum execution-time 240
create upm timer backup-config-timer
configure upm timer backup-config-timer profile backup-config
configure upm timer backup-config-timer after 43200 every 86400
enable upm profile backup-config
UNIX SCRIPT TO CREATE DIRECTORIES
#!/bin/sh
# Create empyt directories for next 5 days
# used to store backup of switch configuration
basedir='/data/tftpboot/switchbackup'
today=`date +'%s'`
for i in 0 1 2 3 4 5; do
nextday=`expr $i \* 86400 + $today`
mkdir -m 777 $basedir/`date +'%F' --date "1970-01-01 $nextday sec"`
done
(from Roland_Mansson)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Jan 4 2012 8:37AM
Macrm,
Great contribution! This can benefit anyone who has not commited to Ridgeline or Epicenter yet.
(from john_padilla)
