Use any controller for 10 Ap 7161 vs 5 Ap 7562
  • Question
  • Updated 1 year ago
  • Answered
Hi everybody
I have 10 Ap7161 and 5 Ap7562 use wing 5.8, What controller do I have to use?
Thank you
Photo of Tuan Nguyen
Tuan Nguyen
  • 678 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 5,954 Points 5k badge 2x thumb
Hi Tuan,
In general every controller will do - usually it is scaling and advanced features what differs.
If you do not tunnel VLANs, you could use i.e. VX9000 as an cost effective way to adopt all APs.
Regards,
Ondrej
Tuan Nguyen
If I do not use the controller, roaming when the client moves between different APs (7161 vs 7562) will lose the connection?
Thanks
Photo of Christoph S.
Christoph S., Employee
  • 3,664 Points 3k badge 2x thumb
Hello Tuan,
For this deployment size you might also want to look at the RFS4000: https://cloud.kapostcontent.net/pub/6df18969-455c-403d-942e-885e210d861b/rfs-4000-data-sheet.pdf?kui...
If you are looking for a hardware controller then your options would be either the NX5500 or RFS4000.
In regards to your roaming question, there are 2 scenarios to consider as follows:
1 - All APs are in the same broadcast domain (layer 2): Roaming will be seamless between APs (no dropped connections) in the absence of a controller.
2 - APs are in different broadcast domains on a routed network (layer 3): There will be a slight disconnect when roaming between APs in different broadcast domains in the absence of a controller. In this case a controller is needed should seamless roaming be a requirement.
Regards,
Chris
(Edited)
Photo of Steven Lin
Steven Lin, Employee
  • 2,342 Points 2k badge 2x thumb
If you are using VC, then VC will in charge of the roaming, but I never try 7161 work with 7562 before because of 7161 is really old product.
The downside to a VC in this case is that as of today, it cannot adopt dissimilar APs. The VC will not resolve the roaming disconnect issue on a routed network. A hardware controller is required. Here's some information on VC adoption on a routed network:
https://gtacknowledge.extremenetworks.com/articles/Solution/Not-able-to-adopt-WiNG-Express-APs-to-a-...
(Edited)
Photo of Timo
Timo
  • 3,210 Points 3k badge 2x thumb
Any plans to change this like Aruba? Adopt different kind of APs works with Aruba Instant. What changed is the problem of one AP have the configuration and not all:
  • Dynamic VC – Provides redundancy in the case of VC (AP) failure. Dynamic VC enables an AP to take on the role of VC when it is elected as RF-domain manager. Supports explicit secondary IP address configuration for seamless management access.
This works with WiNG 5.9.0.
Photo of Alona
Alona, Employee
  • 1,700 Points 1k badge 2x thumb
For 15 APs you don't need more than one domain. Roaming between Aps will work flawlessly.
Tuan Nguyen
Dear all
Thanks for supporting me, as Christoph Saade said All APs are in the same broadcast domain, I have configured for Ap7562 same Ap7161 and I need use wifi in a wide area and the roaming is smooth.
So do I need to use a controller?
Regards
Hello Tuan,
in this scenario, a controller is not an absolute must for roaming between APs to be seamless. It would be used for ease of management of said APs if so inclined.
Regards,
