Using Azure for NAC Authentication
  • 2
  • Question
  • Updated 4 months ago
  • Answered
Are there any plans for using Azure for NAC/Extreme Control Authentication?
Photo of Bill Handler
Bill Handler
  • 1,434 Points 1k badge 2x thumb
Posted 4 months ago
  • 2
Photo of Kurt Semba
Kurt Semba, Employee
  • 1,462 Points 1k badge 2x thumb
Using the Active Directory hosted on Azure? Do you have Windows clients on your LAN that login to the Azure AD?
Bill Handler
Our customer is moving from on-premise Active Directory to Azure on-line Active Direcotry.
We currently have NAC deployed with .1x internal certificates. We’re going to need to transition them to their new Azure solution.
We can go with all MAC Auth, but I was wondering if there was an Azure solution, or plans for such.
Photo of Kurt Semba
Hi Bill,
here is the response from product management:
In general, I will say that yes there are plans to integrate with Azure as a repository for user identity. Be aware that there are multitude (three as far as I recall...) of possible workflows as advertised by Microsoft. We have yet to explore our direction and use cases. With all that said, no commitment is made at this time for the possible type of integration and timeline.
Thanks
Photo of James A
James A, Embassador
  • 7,492 Points 5k badge 2x thumb
It's possible to use NPS in an Azure against Azure AD Domain Services, so I imagine it'd be possible to hace NAC in Azure authing against Azure AD Domain Services directly or via NPS, then VPN RADIUS back to site.
