Using port 51 and 52 as stack port in X440-G2-48p-10GE4
  • 2
  • Question
  • Updated 9 months ago
  • Answered
I must be missing something. In the x440 I remember stacking using just plain copper cables. Can I not do that using port 51 and 52 with the X440-G2-48p-10GE4 ?
Photo of Hunter Blackwolf
Hunter Blackwolf
  • 100 Points 100 badge 2x thumb
  • sad
Posted 1 year ago
  • 2
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
Hello Hunter,
Stacking requires a 10g connection. If you would like to do alternate stacking then you need to use the ports specified in the "show stacking-support" output.
Photo of Larry Kunz
Larry Kunz, Employee
  • 1,520 Points 1k badge 2x thumb
Hi, Hunter.  Here are a couple of sections in the Hardware Installation Guide that you might find helpful:
For the X440-G2 48-port models, the stacking ports are 49 and 50. 10GBASE-CR SFP+ cables are available in various lengths.
Larry Kunz
Information Development
Extreme Networks
Photo of Steven Lin
Steven Lin, Employee
  • 2,330 Points 2k badge 2x thumb
Hi Hunter,
Below is Extreme stacking tool, hope it's useful for you as well.
https://stackingtool.extremenetworks.com/StackingTool/
Photo of Bin
Bin, Employee
  • 5,372 Points 5k badge 2x thumb
Hi Hunter,
This reference could help you.
ExtremeSwitching X440-G2 Stacking
http://documentation.extremenetworks.com/summit/summit_family_hw_install/Stacking/c_stacking-conside...
Photo of Joe Ang
Joe Ang
  • 140 Points 100 badge 2x thumb
I read all these, but I'm still a little perplexed. I was under the impression we could use a cat6 patch cable on ports 50/51 to stack the switches.  I also called the sales rep and he informed me I did not need to order additional cabling to stack two switches and I can simply use the cat6 ethernet cable, sorry if this is a dumb question, but I've been spending hours on trying to enable alt or native stacking via the patch cables.
I went to show stacking and have native and alt ports 49/50, but it'll only accept spf+.  As per the cable management link, is the most cost effective cable part number 10304? Will the cable need to be extreme branded? Thank you for your assistance.
edit: what is the intended use of port 51/52?
(Edited)
Patrick Voss, Alum
The alternate stacking ports depend on the switch. You can check this with the "show stacking-support" output. The connections need to be 10g so this typically means you need to use a fiber uplink. The SFP's have to be extreme certified in order to be supported by extreme.
