Using NetSight to setup syslog on devices
  • Article
  • Updated 5 years ago
Article ID: 9924
Products
NetSight
NetSight Console
Goals
Use NetSight to configure syslog receivers on devices.
Solution
1.  Right click on the device from the Device Tree and select Syslog Receiver Configuration menu pick.
2.  In the upper portion of the screen (Syslog Receiver Configuration) make sure the IP address is that of the NetSight server or whatever syslog server you wish.  You can also change the Port, Severity and Facilty from this window by clicking on each entry for the IP row in question.
3.  Click the Apply to All Devices button.  The bottom portion of the screen (Syslog Receivers on Devices) should now show the # of receivers increased by 1 and that the new information is set.
Repeat this procedure for each individual device.  Note that this tool can also be run against multiple devices or groups of devices.  Just select each device using the shift or ctrl keys from the Device Tree.
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
