v10.41.08 - dashboard health counter not readable
  • Problem
  • Updated 2 weeks ago
  • (Edited)
After upgrading to v10.41.08 the Health counters on the dashboard are not within the screen because the description was changed from "Lowest AP Uptime (min)" to "Lowest AP Tunnel Duration (min)".
before upgrade = v10.41.07
after upgrade = v10.41.08
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,586 Points 20k badge 2x thumb
Posted 2 weeks ago
Photo of Robert Zdzieblo
Robert Zdzieblo
  • 1,186 Points 1k badge 2x thumb
You can always decrease the font size within the browser. Does if fit after that ?
That doesn't affect the GUI font size.
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,160 Points 2k badge 2x thumb
Hi Ron,
I will create a case on your name and will escalate it to Engineering.Thanks for the hint.
Regards
Umut Aydin
  • 45,564 Points 20k badge 2x thumb
Thx
Photo of Umut Aydin
FYI - Here the case 01709561
Photo of Craig Guilmette
Craig Guilmette, Employee
  • 2,500 Points 2k badge 2x thumb
it is a known issue should be fixed in 10.41.09 bug # wns0020699
