v160 operation how does the Hash algorithm work. I am looking to install an extreme switch in an SAN enviroment
  • Question
  • Updated 2 years ago
  • Answered
Looking to use 2 x QSFP+  (V160) links between X670-G2 or X770 for a SAN type environment , the link will be between two data centers on the same site , breaking the Qspf+ into fiber hydra cables .
Photo of Rod Robertson
Rod Robertson
  • 2,344 Points 2k badge 2x thumb
Posted 2 years ago
Photo of Ron Huygens
Ron Huygens, Employee
  • 2,878 Points 2k badge 2x thumb
Hi Rod,
I assume that you are using the QSFP ports, partitioned in 2 time 4x10gig links and form a LAG towards the SAN?
If the answer is yes, the hashing possibilities are similar to any LAG withing EXOS.
Rod Robertson
 Many Thanks
Ok we have 8 x 10 gig links then .. its what I thought just had to make sure ..
this is for a proposed SAN installation , is there a better way of connecting these units for this SAN solution.
Regards
Rod
