V2110 Controller not booting "Kernel Panic"- Not Syncing: VFS: Unable to mount root f on unknown-block
  • Question
  • Updated 2 years ago
  • Answered
Hi, please help as I am planning to test our extreme AP 3715i using a V2110 controller on my Laptop. I am unable to boot the V2110-10.11.03.0004.ova file that was sent to me via Case. I'm getting error message "V2110 Controller not booting "Kernel Panic"- Not Syncing: VFS: Unable to mount root f on unknown-block"
I have VMWare version 9.0.2 and my laptop is Dell Inspiron 5000 with Intel Core i5 and 8GB RAM. I think this passed the system requirements for virtual controller.
Here's the screenshot of the error message that I'm getting.
I would appreciate any help I could get to resolve this problem.
Thank you in advance.
Photo of Gerald Nuque
Gerald Nuque
  • 388 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Take a look at this..
https://gtacknowledge.extremenetworks.com/articles/Solution/V2110-Controller-Showing-Error-When-Boot...
Don't know if that will help.... Also, not 100% sure if you can use VMWare Workstation for this.. I thought you would need ESX or ESXi.
(Edited)
Photo of Jeremy
Jeremy, Embassador
Gerald Nuque
Thank you Jeremy, will check your solutions. Hope it'll work.
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,578 Points 5k badge 2x thumb
Gerald
Whilst this might work it is not a supported configuration, v2110 requires hyper-v or ESXi 5.5 or 6.0.
-Gareth
