V2110 interfaces don't work in tagged mode
  • Problem
  • Updated 1 year ago
  • Solved
Hello, everybody!
I got a strange issue with V2110 controller. It works under Hyper-V.
When I mark its interfaces in Hyper-V as trunks (without exact VLAN), it stops working. I mean, I loose connectivity to controller and from controller.
When I implicitly set up interfaces in Hyper-V as VLAN 38 and VLAN 39 - I can reach them and I can reach gateway for both of them from V2110.
This is kind of problem... What if I would like to setup more then two WLANs?
I want also to keep APs in a different network. MGMT interface is not appropriate for this.
At the moment I can't setup default routing from controller. I want to create new "tagged" topologies... but they doesn't work. All VLANs are configured properly.
What could be the problem?
Many thanks in advance,
Ilya
Photo of Ilya Semenov
Ilya Semenov
  • 4,610 Points 4k badge 2x thumb
Posted 1 year ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,502 Points 20k badge 2x thumb
(Edited)
