V400 VPEX Design
V400 VPEX Design
LeoP1
Contributor
Hi Guys,
We are working on a project to an existing Legacy-Enterasys customer, to fight Aruba's approach on a customer using 2 X690 as Cores, and thinking about V400 Bridge Port Extenders for access (using 1G uplinks due to customer needs and infrastructure constrictions)...
The problem is the customer's "rings"... They are mandatory to the customer, because they want redundancy to the access. Do you think any of the following designs could work???
7163199de18d4912a53ad551b483e019_RackMultipart20180731-17862-1f6esos-Design1_inline.png
Best regards,
-Leo
6 REPLIES 6
akrasnyakov
Hello guys.
A lot of partners and customers ask if the redundant server connection is supported with this design.
LeoP1
Contributor
Hi Nikolay and Stephen,
I don't think MLAG design would work, because the customer won't have double direct uplinks to core in all BPE (actual design is just like the example 1 above).
Thanks for your help!
Best regards,
-Leo
Hello Leonardo,
The following design when the only top BPE has double links to Core is also supported. Bottom BPEs may have single link connection or LAG.
d7bc594a5a52497e9535ba1bbeab8975_RackMultipart20180801-19234-frog77-Picture1_inline.jpg
/Nikolay
Hi Leo,
We plan to support Ring topology in Extended Edge Switching to provide redundancy in EXOS 22.7.x.
Best regards
Bin
