VDX firmware downgrade form 7.* to 6.*
  • 2
  • Question
  • Updated 3 weeks ago
Hello,
I Would like to downgrade the firmware version on VDX 6740 from 7.3.0 on 6.0.2 on one switch.
is there any particular procedure ?
Is it the same procedure as firmware upgrade ?
thanks
Photo of Riccardo Veraldi
Riccardo Veraldi
  • 282 Points 250 badge 2x thumb
Posted 3 weeks ago
  • 2
Photo of Mick Day
Mick Day, Employee
  • 470 Points 250 badge 2x thumb
The procedure is much the same as upgrade, only a single major release at a time if you want to 7.3.x -> 7.2.x -> 7.1.x -> 7.0.x -> 6.x
If you are not worried about the configuration downgrade can be performed directly with default config
Consult the release notes for any caveats between specific versions
