VDX6740 Booting Problem
Nukhet_Aslan1
I have a BR-VDX6740T and while it is booting gives the error below . What could e the source of problem?
Thank you
INIT: version 2.78 booting
e2fsck 1.41.12 (17-May-2010)
/dev/sda1: clean, 15806/122160 files, 183016/488281 blocks
/dev/sda2: recovering journal
/dev/sda2: clean, 6976/122160 files, 124698/488192 blocks
Firmware Integrity Check is default off
Bypassing firmware validation.
mount: sysfs already mounted or /sys busy
mount: according to mtab, none is already mounted on /sys
mknod: /dev/fsl-hv: File exists
Hostname is VDX-10
INIT: Entering runlevel: 3
FIPS-mode test application
1. Non-Approved cryptographic operation test...
a. Excluded algorithm (MD5)...successful
b. Included algorithm (D-H)...successful
2. Automatic power-up self test...successful
3. AES-128,192,256 CBC encryption/decryption...successful
4. RSA key generation and encryption/decryption...successful
4.1. RSA 2048 with 'SHA256' testing...successful
5. TDES-CBC encryption/decryption...successful
6a. SHA-1 hash...successful
6b. SHA-256 hash...successful
6c. SHA-512 hash...successful
6d. HMAC-SHA-1 hash...successful
6e. HMAC-SHA-224 hash...successful
6f. HMAC-SHA-256 hash...successful
6g. HMAC-SHA-384 hash...successful
6h. HMAC-SHA-512 hash...successful
7. Non-Approved cryptographic operation test...
a. Excluded algorithm (MD5)...Not executed
b. Included algorithm (D-H)...successful as expected
8. Zero-ization...Successful
9. TLS KDF...successful
10. SSH KDF...successful
All tests completed with 0 errors
Waiting to starting configuration management service
Starting configuration management service
[wmd_init]: chunk_size = 0xa00000
[wmd_init]: Checksum does not match. current_cksum = 0x16c0388f stored_cksum = 0x8fd5a6c1
[wmd_init]: FPGA version = 0x70007445
[wmd_init]: reset_reason = 0x1
[wmd_init]: updated reset_reason = 0x0
Reset reason = 0x1
wmem: b0004000:247439360
tbuf: 8ff00000:536854528
Found 1(threshold 5) abnormal reboots within 3000 seconds window(threshold)
KernelSpace rastrace_register
SWBD module launch ... Thu Aug 9 17:19:56 EEST 2018
Castor: PCIe Err handler init plat_pci_init[636]
bhpc_irq_init: Using default device map. Size 10
pcie_event_isr: ###### virq 174 core 1 MCSR 0x0 MSR 0x10021002 count 1
plat_pcie_error:Last addresses 0x0 0x0 0x0 0x0
0x0 0x0 0x0 0x0
0x0 0x0
CPLD INIT DONE
PCIe Event [unknown] slot 0 Source Bus 0 Dev 0 MM Parent Bus 0 Dev 0 Events: 1
AQ1402: Loaded Platform 137
MDIO Driver: Name [Freescale P4080DS MDIO Bus], Address [8acaa220]
GPIO CCSR phys addr = 0xffe130000, virt addr = 0xd830a000
cbr_rev_init: pci config word 0xc0220008 for Castors
cbr_rev_init: prs_reg[0].ctrl=0x00000102
cbr_rev_init: chip_rev detected=2
Cobra rev B found
Found Castor-T Type board Blade ID 145
Info: panic dump has been initialized!
Creating L3-L2 fifo Thu Aug 9 17:20:07 EEST 2018 ...
Starting HASM ... Thu Aug 9 17:20:07 EEST 2018
Exisitng reboot reason fsize = 5 rb=
usb 1-1: device descriptor read/64, error -110
usb 1-1: device descriptor read/8, error -110
end_request: I/O error, dev sda, sector 65609
EXT4-fs error (device sda1): ext4_find_entry: reading directory #7044 offset 0
Aborting journal on device sda1-8.
EXT4-fs (sda1): delayed block allocation failed for inode 7022 at logical offset 0 with max blocks 1 with error -30
This should not happen!! Data will be lost
EXT4-fs error (device sda1) in ext4_da_writepages: Journal has aborted
EXT4-fs (sda1): previous I/O error to superblock detected
EXT4-fs error (device sda1) in ext4_new_inode: Journal has aborted
EXT4-fs error (device sda1) in ext4_reserve_inode_write: Journal has aborted
/etc/rc.d/rc3.d/S99sshd: /usr/sbin/sshd: Input/output error
EXT4-fs error (device sda1) in ext4_da_write_begin: IO failure
EXT4-fs error (device sda1): ext4_journal_start_sb: Detected aborted journal
EXT4-fs (sda1): Remounting filesystem read-only
EXT4-fs (sda1): ext4_da_writepages: jbd2_start: 1024 pages, ino 7022; err -30
INIT: cannot execute "/sbin/getty"
EXT4-fs (sda1): I/O error while writing superblock
JBD2: I/O error detected when updating journal superblock for sda1-8.
journal commit I/O error
[store_cksum]: /var/wmd_cksum does not exists.
Unable to handle kernel paging request for data at address 0xfffffff2
Faulting instruction address: 0xc1502630
Oops taken on: 2018-08-09 at 14:22:06
Oops: Kernel access of bad area, sig: 11 [#1]
PREEMPT SMP NR_CPUS=4 LTT NESTING LEVEL : 0
SILKWORM PB HV
NIP: c1502630 LR: c15026f8 CTR: 40577514
REGS: 8520fc70 TRAP: 0300 Tainted: P (2.6.34.6)
MSR: 10029002 CR: 28000428 XER: 20000000
DEAR: fffffff2, ESR: 00000000
TASK = 881809a0[1781] 'hasmd' THREAD: 8520c000
Last syscall: -1 CPU: 0
GPR00: c15026f8 8520fd20 881809a0 ffffffe2 4079d9c0 4075ed40 ffffffff ffffffe0
GPR08: c1503bb4 000001dd 00000063 8520fd20 28000484 100609c0 10082354 0ffc5438
GPR16: 00000000 ffff9008 00000089 00000000 3f842b77 0000006e 3fffffff c1503934
GPR24: c1503bb4 c15046c0 8f601fe0 c15044c4 8f4ffd80 00000002
EXT4-fs error (device sda1): ext4_find_entry: ffffffe2 8520fd20
NIP [c1502630] wm_dumper_fops_ioctl+0x2dc/0x3c8 [wmdumper_module]
LR [c15026f8] wm_dumper_fops_ioctl+0x3a4/0x3c8 [wmdumper_module]
Call Trace:
STACK MAGIC 0x57ac6e9d
[8520fd20] [c15026f8] wm_dumper_fops_ioctl+0x3a4/0x3c8 [wmdumper_module] (unreliable)
[8520fe70] [4011f4c0] vfs_ioctl+0xbc/0xec
[8520fe90] [4011f6f8] do_vfs_ioctl+0x94/0x774
[8520ff00] [4011fe98] sys_ioctl+0xc0/0x12c
[8520ff40] [40011e64] ret_from_syscall+0x0/0x3c
Instruction dump:
9002024c 3b093bb4 7f03c378 38800002 38a00000 4800121d 3800f000 7f830040
7c7e1b78 419d00b4 2f9e0000 419e0090 <813e0010> 8009000c 2f800000 419e0074
last sysfs file: /sys/bus/usb/drivers/hub/unbind
PowerPC Book-E Watchdog Shutdown soft timer
panic_dump_notifier nb=c1554aa4 a=1
[wm_dump_write]: WMD METADATA SECTION IS CORRUPTED. FAILING WRITE
[wm_dump_write]: Stored cksum = 0x16c0388f calculated cksum = 0x8fd5a6c1
PD Start
[flash_or_ata_open_wrapper]: Dumper is writable
[panic_dump_save]: DOOPEN succeeded
panic_dump_save: Saving DIE...
[panic_dump_save]: collecting panicdump
[flash_or_ata_write_wrapper]: write rc = -1
flash_dump_write()=-1, buf=8520fae0, size=0x64
[panic_dump_meta_header]: Dumping meta header failed.
panic_dump_save: Dumping OOM_DUMP...
OOM_DUMP
[panic_dump_write_block]: Header write failed.
[panic_dump_write_block]: Buffer write failed.
[panic_dump_write_block]: Filler write failed.
panic_dump_save: Dumping reboot_reason...
reboot_reason
set_reboot_reason reason=Software Fault:Kernel Panic
flush reboot_reason reason=Software Fault:Kernel Panic
panic_dump_save: Dumping PLATFORM...
PLATFORM
panic_dump_save: Dumping MLT...
MLT
panic_dump_save: Dumping PD_MISC...
PD_MISC
panic_dump_save: Dumping CONSOLE_LOG...
CONSOLE_LOG
panic_dump_save: Dumping KERNEL_STACK_DUMP...
KERNEL_STACK_DUMP
panic_dump_save: Dumping PDTRACE...
PDTRACE
Start WM tracedump
End WM tracedump
panic_dump_save: Dumping PANIC_DUMP_LOG...
PANIC_DUMP_LOG
[panic_dump_save]: dump the trailer
panic_dump_save: Panic dump completed
Dump Started at: 00000000e7639896
Dump Ended at: 00000000e78c2210
Dump Time Taken (in 100MHz) = 000000000028897a
[panic_dump_save]: Panic dump completed
hv restart
[0] restart_guest_remap: self is calling remap_restart_unc due to: hcall_partition_restart_ha.
[0] loading binary image from 0x79fff000 to 0x3000000
[0] Loading uImage from 0x78000000 to 0
[0] branching to guest p1-linux, 2 cpus
HV> this is quiet!
end of DRAM 4294967296 memstart_addr0 total_lowmem 4294967296
SLUB: dfree enabled
PRIMING SLUB: main caches
SLUB: export __kmalloc at 0x401068c0 changed to 0x40106c80
SLUB: export vmalloc at 0x400f55a8 changed to 0x400f535c
SLUB: export vfree at 0x400f4748 changed to 0x400f4678
network namespace NR (VRF) started
mdio_bus mdio: /devices/fman0/mdio@f1000/p4080ds-xmdio1 has invalid PHY address
mmod_sysctl_inited: 1
Fman microcode 51 45 46
FMAN microcode UC size 0x1b64
default MII is 0xc10a8000 for tsec0
default MII is 0xc10b0000 for tsec0
CastorT i2c unlock, ret=-2
Uboot wdt counter value: 0
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[1] restart_guest_remap: self is calling remap_restart_unc due to: hcall_partition_restart_ha.
HV> this is quiet!
SLUB: dfree enabled
HV> this is quiet!
SLUB: dfree enabled
3 REPLIES 3
Steffen_Schwade
please change the boot partition to SDA1
Michael_Andreas
what version you are running on the 6740
Yulia_Abitbul
"Unable to handle kernel paging request for data at address 0xfffffff2Faulting instruction address: 0xc1502630
Oops: Kernel access of bad area, sig: 11 [#1]"
That could be hardware failure, we need to check core_files to be sure.
Does it happen only once?
it is better to open a case to TAC team
