view difference between the running configuration and startup configuration with EXOS
  • Question
  • Updated 2 years ago
  • Answered
How can display the difference between the running configuration and startup configuration with EXOS
Photo of chandip
chandip
  • 110 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,420 Points 3k badge 2x thumb
Hi Chandip,
There isn't an official supported way to do this, however there is a script on our GitHub that will get this done:
https://github.com/extremenetworks/ExtremeScripting/tree/master/EXOS/Python/conf_diff
There is an important caveat to the script that I felt should be mentioned. The script will remove the asterisk (or dirty bit) from the prompt. Under the hood, the script saves the configuration to a temporary file and then deletes the temporary file. Since the configuration technically gets saved to that temporary file, the dirty bit is cleared.
You'll need to actually save your configuration changes should you want to do so.
Photo of chandip
chandip
HI Brad
Thanks for the prompt reply. I should of stated without scripts in my original question. It seems we can achieve most things with the scripts J.
It’s just not practical when viewing remote sessions with the customer. A “show running-config diff” would be nice. I will put in a feature request for this.
Thanks
Chandip
