Virtual_EXOS Openflow module
  • 2
  • Question
  • Updated 1 year ago
  • Answered
I am trying to setup an Openflow lab with Extreme switches using GNS3 and qemu based EXOS VM. I have imported the appliance and it works with no surprises so far.
Then I tried to update the appliance using the files I have from our physical devices (X440 & X460) but I get the following error message:
Error: Failed to download image - Error: File SUMMIT is not suitable for UNKNOWN.
Is there any workaround for this or this is not current limitation of EXOS VM?
Photo of Tasos Vlachogiannis
Tasos Vlachogiannis
  • 156 Points 100 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,608 Points 10k badge 2x thumb
Hi Tasos,
You need to use the vm .xos files to upgrade the VMs. You can find those over on our Virtual EXOS Github page.
Tasos Vlachogiannis
Hi Brandon,
Thanks for the reply. What about the Openflow module? Is there also a modified version that works with EXOS VM? couldn't find anything at gihub repo..
Hi Tasos,
Starting in EXOS 21, the OpenFlow module is bundled in with the EXOS base image. I've uploaded the OpenFlow xmod for 16.2 to Github now, located here.
Tasos Vlachogiannis
Thanks Brandon. I have now installed the Openflow module. Do I need to buy an extra licence to use openflow with the exos vm?
Photo of Drew C.
Drew C., Community Manager
  • 40,684 Points 20k badge 2x thumb
What's the MAC address of the VM? (from show switch)? I'll provide the license for you.
Tasos Vlachogiannis
Hi Drew,
Thanks for doing this. For now I have just a couple of switches with MAC addresses:
00:3F:14:AF:17:00
00:3F:14:B7:37:00
In case I want to add more switches to my virtual topology what is the way to move forward? Do we have to acquire a bunch of licence keys for EXOS virtual appliances?
Photo of Drew C.
You're welcome! Here are the licenses for those two virtual switches.
00:3F:14:AF:17:00 -> 9d68-8214-da17-0225-8ffe
00:3F:14:B7:37:00 -> 9d68-8214-da17-0225-fe8f
For future use, you can enable the trial license, which includes OpenFlow.
http://documentation.extremenetworks.com/flr_22.2/exos_21_1/feature_license_requirements/c_trial_lic...
Tasos Vlachogiannis
How can I use exos firmware version 16.2.1.6 with GNS3? Latest appliance file on github (exosvm.gns3a) has dropped support for this version.
Thanks
