Virtual Summit Switches limitations
  • Question
  • Updated 2 years ago
  • Answered
Hello, everybody!
I have set up an virtual environment of 11 switches to test MLAG and VRRP before implementing in real customer's infrastructure. (Everything was taken from I use 16.1.x EXOS.
Where can I find information about limitations of these virtual switches? I try to make stacking between two switches and get: "Error: This method is not supported on this platform".
May be there are some other limitations?
Could anybody help me?
Many thanks in advance,
Photo of Ilya Semenov
Ilya Semenov
  • 3,622 Points 3k badge 2x thumb
Posted 2 years ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,214 Points 10k badge 2x thumb
You can't choose what platform you can use therefore you cant stack them together.  The VE is used just for EXOS access not necessarily the physical hardware. However, the only difference between a stack and a standalone switch is the port layout. This means the behaviors should be the same.
Photo of Drew C.
Drew C., Community Manager
  • 36,016 Points 20k badge 2x thumb
Hi Ilya,
Virtual EXOS doesn’t support anything that requires a hardware packet processor.  This means that IPFIX, VxLAN, MPLS, VPLS, Policy, etc. won’t work.  You can configure them, but the data plane won’t work.  MLAG, EAPS, and VRRP, however, I believe will work fine.
As Patrick mentioned, the Virtual EXOS platform is not able to be "stacked."
Ilya Semenov
Thank you, now it's clear.
Photo of Matthew Helm
Matthew Helm, Employee
  • 1,852 Points 1k badge 2x thumb
LAG is limited as well. LACP is supported but there is support for anything other than the round-robin based load sharing algorithm.
