How to disable VLAN routing
  • Problem
  • Updated 8 months ago
  • Solved
  • (Edited)
Hi, I Created two VLAN and two SSID in AP 7522E.. That SSID name as First & Second. Vlan1 is 192.168.1.10 & Vlan2 is 192.168.2.10 series. SSID First is assigned to Vlan1, Second is assigned to Vlan2. Now i connected two system as two different SSID's. But these both systems are communicated. How to avoid this problem.
Photo of Saravanamurthy K
Saravanamurthy K
  • 662 Points 500 badge 2x thumb
Posted 8 months ago
Photo of Wei Pin Lim
Wei Pin Lim, Employee
  • 340 Points 250 badge 2x thumb
By configuring the WLAN ACL Rules will stop VLAN 1 and VLAN 2 communicate to each other.
In the GUI
Go to Configuration > Security > WLAN ACL Rules,
Configure rules to block the VLAN1 and VLAN 2 communication.
Remember to select the correct interface as It will automatically applied on the Interface WLAN you had selected.
Hope this help.
Thanks.
Wei Pin
Saravanamurthy K
thanks
