Vlan(trunk) on port channel?
  • Question
  • Updated 6 days ago
hi guys,
I'm hoping this is possible - scenario is:
a port channel (2 switches x 1 port) which is a vlan 9. That port channel is in access mode.
Can I use eth interfaces/ports(some or all) of that channel in trunk mode? (for iscsi)
Eg.:
Te 1/0/45  + Te 2/0/45 = Po 25 in access mode vlan 9
Te 1/0/45  = in trunk for vlan 9 & 99 ?
How this could be achieved?
Many thanks, L.
Photo of Pawel Eljasz
Pawel Eljasz
  • 480 Points 250 badge 2x thumb
Posted 6 days ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,164 Points 50k badge 2x thumb
What product/model are we talking about here !?
And no you can't configure part of a LAG - all ports in the LAG have the same configuration.
Photo of Yulia Abitbul
Yulia Abitbul, Employee
  • 516 Points 500 badge 2x thumb
No, you can not configure same port as access and trunk at the same time
Pawel Eljasz
Thanks,
it's BR-VDX6740 with 7.2.0a1
So if a node/client has only two ports and need to talk to two subnets, then either no port channel or iscsi over that port channel (which I hear/read is not good)
Routing !? I've one port on my client and talk to all subnets on this planet.
Might be good if you post a network diagram and a little bit more information.
Photo of Sargis Minasyan
Sargis Minasyan
  • 110 Points 100 badge 2x thumb
if the client supports hashing based on IP/port, each iSCSI flow should take one path only and not be affected by any variable latency on LAG members. If you expect generally high load on interfaces, you might also want to mark iSCSI with a different COS/DCSP, if possible, and map to a separate Traffic Class on VDX.
