VMware esxi4.1 --> MLAG for management traffic?
  • Question
  • Updated 4 years ago
Create Date: Apr 11 2013 3:22PM
has anyone got MLAG working for the management portgroup with esxi 4.1?it works fine for the vm traffic, but the managment vlan doesn't work, anyone got this working, i suspect it doesn't because you tend to find "are you sure you need redundancy for the managment traffic?
(from conrad_jones)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Apr 12 2013 1:30PM
good morning Oxide54
I have not see or heard of this issue.  One question I have is did you try just creating a regular share port from the management to a single switch?  that would tell us if it is on the MLAG side or the server side.
Thanks
P
(from Paul_Russo)
