Voice VLAN - Cisco IP Phone - CDP
  • Question
  • Updated 1 year ago
  • Answered
One of my customer is connecting Cisco IP Phone with Extreme switch but it is not getting register automatically because of its default VLAN 4095. Do we need to change VLAN of IP Phone manually or it should workout with CDP?
Photo of Waqas Naeem
Waqas Naeem
  • 814 Points 500 badge 2x thumb
  • undecided
Posted 2 years ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,376 Points 5k badge 2x thumb
Hi Waqas,
Although EXOS supports CDP the feature what you are looking for is not available yet but you can determine if the phones supports LLDP and switch can advertise the VLAN via LLDP or you can assign the VLAN manually.
Here is the link to Article on configuring LLDP
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 7,912 Points 5k badge 2x thumb
One comment. Vlan 4095 is reserved by IEEE 802.1q standard.
Not all products and not all vendors do support 4095 as other vlans.
Not sure if this can be issue here
Waqas Naeem
Thanks Zdenek for your valuable feedback.
Does Cisco support 4095 as other vlan?
Photo of Henrique
Henrique, Employee
  • 10,282 Points 10k badge 2x thumb
Hi Waqas, please check the articles below for some additional information:
How to configure LLDP for Extreme switches to recognize IP phones
What is the EXOS equivalent of the Cisco 'switchport voice vlan' command
Photo of FES
  • 1,360 Points 1k badge 2x thumb
In addition to the post, I am trying to configure cisco ip phone detection using CEP auth to split voip data and pc data.
We are trying this because you can do this using Policy Manager and dont need to configure ciscodp using cli in the device.
At the moment, when the voip phone is detected by cep (with ciscodp cep option and policy) the phone works correctly using the vlan configure in the policy but also the pc is configured automatically in the voip vlan...
Somebody have CEP authentication working witch voip phone and pc?
