VoIP video problem
  • Question
  • Updated 4 years ago
  • Answered
We are putting out new Extreme switches (x460 and x440) into different buildings. We are running 15.3.2.111. We use cisco phones for our VoIP. We have models 8945 and 9951 which also provide video. They have worked great in our test building (which was small), however now the video isn't working in the newer deployments. We are using netlogin to authenticate all devices. When a phone is authenticated (mac auth) a UPM profile is ran to turn on lldp and set dscp...
You can make calls without a problem. I'm wondering if there is an uplink/downlink setting that we need that I have completely forgot about. Below is what our UPM script.
Any help/suggestions would be greatly appreciated!
# Module upm configuration.
create upm profile c_PHONE_UPM
# @MetaDataStart
# @ScriptDescription This Profile is Used to Provision a Port for a Phone Once i
t's Been Authenticated.
# @MetaDataEnd
create log message PHONE_AUTHENTICATE_SCRIPT
if (!$match($EVENT.NAME,USER-AUTHENTICATED)) then
create log message PHONE_AUTHENTICATED_CONFIGURING_PORT_$EVENT.USER_PORT
configure lldp port $EVENT.USER_PORT advertise system-capabilities
configure lldp port $EVENT.USER_PORT advertise vendor-specific med capab
ilities
# advertise the 802.1Q tag for the Phone Vlan
configure lldp port $EVENT.USER_PORT advertise vendor-specific dot1 vlan
-name vlan Phone
# advertise the DSCP for the phone to use
configure lldp ports $EVENT.USER_PORT advertise vendor-specific med poli
cy application voice vlan Phone dscp 46
#advertise PoE capabilities (some Cisco phones require this)
configure lldp ports $EVENT.USER_PORT advertise vendor-specific med powe
r-via-mdi
#turn on lldp on the port
enable lldp port $EVENT.USER_PORT
# ignore 802.1p bits on the edge ports (the phones are sending a Qtag wh
ich always have pbits)
disable dot1p examination ports $EVENT.USER_PORT
# replace the 802.1p bits when forwarding packets
enable dot1p replacement ports $EVENT.USER_PORT
enable snmp traps lldp ports $EVENT.USER_PORT
create log message END_OF_PHONE_AUTHENTICATED_$EVENT.USER_PORT
endif
if (!$match($EVENT.NAME,USER-UNAUTHENTICATED)) then
create log message PHONE_IS_UNAUTHENTICATED_$EVENT.USER_PORT
disable lldp port $EVENT.USER_PORT
disable snmp traps lldp ports $EVENT.USER_PORT
endif
Photo of bw447
bw447
  • 916 Points 500 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Official Response
Hey Blake
if you disable .1p you probably you don't need to set the 1.p value to a queue or replace it unless the next switches inline are looking at .1p
The switch has a hierarchy to how we look at QoS parameters.  ACLs have the highest priority, then .1p then VLAN then DSCP. so if you do not use ACL or .1p the switch will then use VLAN.
The commands you issued above are ok and will not affect the switch just may not be needed if the switches are set to disable .1p examination.
Does that help?
P
