VOSS: console messages in current SSH session
  • Question
  • Updated 4 months ago
  • Answered
In some troubleshooting cases i need log / console messages in current SSH CLI session.
In EXOS i can use "enable log target session" to redirect console log messages to current SSH session.
I am sure this is also possible in recent VSP 7200 VOSS (6.1.x).
Photo of M.Nees
M.Nees, Embassador
  • 9,466 Points 5k badge 2x thumb
Posted 4 months ago
Photo of Joseph Wood
Joseph Wood
  • 112 Points 100 badge 2x thumb
Can you provide an example of a message that is getting logged to the console that is not also showing up in the log (show log file tail)?
Photo of M.Nees
M.Nees, Embassador
Hi Joseph,
i am connected to Serial console and i get this kind of status messages:
TOR11:1(config)#
TOR11:1(config)#
TOR11:1(config)#
TOR11:1(config)#1 2018-06-14T09:05:17.990+02:00 TOR11 CP1 - 0x000e0598 - 00000000 GlobalRouter HAL INFO GBIC inserted in slot 1 Port 1 Type:GbicSx Vendor:JDS UNIPHASE
TOR11:1(config)#1 2018-06-14T09:06:08.360+02:00 TOR11 CP1 - 0x00088524 - 00000000 GlobalRouter SW INFO Boot sequence successful
1 2018-06-14T09:08:08.282+02:00 TOR11 CP1 - 0x0006469b - 00000000 GlobalRouter MLT WARNING smltTick: The IST control channel failed to come up within 240 seconds; unlocking SMLT ports.
1 2018-06-14T09:08:16.819+02:00 TOR11 CP1 - 0x000e0597 - 00000000 GlobalRouter HAL INFO GBIC removed from slot 2 Port 5 Type:40GbCR4 Vendor:Extreme
1 2018-06-14T09:08:25.908+02:00 TOR11 CP1 - 0x000e0598 - 00000000 GlobalRouter HAL INFO GBIC inserted in slot 2 Port 5 Type:40GbCR4 Vendor:Extreme
TOR11:1(config)#
TOR11:1(config)#
So the switch tell me status changes about hardware, Interfaces, Routing, SPBM, etc
in some cases - if i have only a ssh session (and no serial console - because i am remote connected) i want to redirect this kind of messages to the local ssh session.
Currently i have to check "show logging file tail" every seconds if i expect some change.
The searched functionality is more elegant because the occured message are pop up / injected into my ssh session.
Regards,Matthias
Photo of M.Nees
M.Nees, Embassador
Hi all,
i get an advice.
"conf t"
"logging screen enable"
This should redirect log messages to ssh session (i does not test yet).
Regards
