VOSS "Default" command
  • Question
  • Updated 1 month ago
  • Answered
What about the "default" command in VOSS ?
I see this command at interfaces, MLT, etc. and at global command level.
Here an example (VSP7200 - V7.0.0):
SW11:1(config-mlt)#?
default     Default settings
SW11:1(config-mlt)#default ?
Default settings
  flex-uni       Set flex-uni to default on mlt interface
  ip
  isis           set interface level isis parameters to default value
lacp Set lacp for specific mlt to default
smlt           Create default smlt on a specific mlt
svlan-porttype Set svlan port type to default
virtual-ist    Create virtual-ist on MLT with default value
SW11:1(config-mlt)#
Unfortunately i do not find any manual where this command or the usage will be explained. CLI Reference does not explain this command.
Do anyone tell me which VOSS manual explain the usage ?? Or have anyone an example how to use this command ?
Regards
Photo of M.Nees
M.Nees, Embassador
  • 9,414 Points 5k badge 2x thumb
Posted 3 months ago
Photo of Ludovico Stevens
Ludovico Stevens, Employee
  • 410 Points 250 badge 2x thumb
It restores a setting to its default value (i.e value it would have under switch factory defaults)
Photo of M.Nees
M.Nees, Embassador
Does the value restore to "factory" default or can i define a custom default value ?
Do you know which manuel does explain that ?
Restores value to factory default. No, you cannot define a custom default value."default" and "no" are standard command modifiers which can precede CLI configuration commands, to default or negate a config setting.This is supposed to be Cisco-like.I guess it should be in the Using CLI guide, but seems not to be there...
Photo of Roger Lapuh
Roger Lapuh, Employee
  • 470 Points 250 badge 2x thumb
here is where the default operator is explained:   starting on page 17. I hope this helps.
