VOSS: Filtering of show command output
  • 2
  • Question
  • Updated 4 months ago
  • Answered
In EXOS i use very often in daily business filtering of show command output.
show command syntax | {include |exclude |begin }regexp
Working now with VOSS V6.1.x i miss that very hard, so i am looking for some equivalent.
Photo of M.Nees
M.Nees, Embassador
  • 9,538 Points 5k badge 2x thumb
Posted 4 months ago
  • 2
Photo of Roger Lapuh
Roger Lapuh, Employee
  • 470 Points 250 badge 2x thumb
Filtering and grep commands have been added with VOSS Release 7.0.
Photo of M.Nees
M.Nees, Embassador
Hi Roger,
thanks for that useful advice - i found it Release NOoes and CLI / EDM Admin Guide.
Enter the show command followed by the pipe (|) character, followed by the GREP filter command.
The show command output contains only the lines that match the GREP filter pattern.
This is available for VSP7200.
I need it for VSP8600 too.
Do you know if the upcoming VOSS 6.2 (for VSP8600) also include this new feature ?
Regards,Matthias
