VPLS layer 3 ?
  • 2
  • Question
  • Updated 3 years ago
  • Answered
Good morning everyone, I am a beginner in mpls and I have some doubts.
I need to create a VPLS with ip / 30 on each side, which would be the best way?
when configuring the IP on a vlan, it is not possible to configure the VPLS service.
what is the best way to do this?
Photo of Jader
Jader
  • 110 Points 100 badge 2x thumb
Posted 4 years ago
  • 2
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
There is configuration example in concepts guide.
you need to have ospf for IGP.
Then MPLS enabled .
Add VPLS service vlans.
Photo of Jader
Jader
hello, I mpls working perfectly (when using vlan in layer 2).
When configuring IP on a vlan that as the VPLS service got the following error:
* X480-IXX enable ipforwarding  vlan-3
Error: vlan VLAN-3 is enabled for VPLS!
(Edited)
Photo of Brunno Lopes
Brunno Lopes
  • 218 Points 100 badge 2x thumb
I ́ve gone through the same issue here. We need to have 2 remote switches, running VRRP over a VPLS service. I can't transport the VLAN between these 2 switches through trunk ports, the only way to accomplish this is by using MPLS/VPLS. These 2 switches must have L3 access to the IPv4 table.
Is there any solution without an external equipment?
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,284 Points 10k badge 2x thumb
The VPLS service vlan cannot have ipforwarding enabled. The GW function should then be on a separate device. Consider your mpls switches as PE/P and let the CE act as L3 GW. I never tried an external loopback interface to recirculate the packet. Not sure if this would work.
No issue to run an IGP between the mpls switches, using /30 or /31 subnet.
Brunno Lopes
Then you confirm that an external device is needed to have a routed/managed VPLS? This would be a limitation and other vendor's MPLS switches perform this type of service. This would be important to provide, on the same PE, both L2 (VPLS) and L3 service.
I ́ve also seen on the "Exos 15.7 User Guide" an statement that says "Forward between normal VLAN/VMAN and Openflow pseudowires using standard Ethernet..." (page 1467). Would it be possible to have a VLAN with IPForwarding to an openflow pseudowire?
Would there be any possibility to have this running also on a PWE3 with selective VMAN?
This is a real need on our network, and we can't have an external device to perform this function.
