VRRP fabric routing, secondary IPs and IPv6?
Frank
Contributor
Now that fabric routing has caught my attention, I have a couple of questions (for 16.2+, I don't think I can run 21+ on my BD8806)
1) Does it work with secondary IP addresses (config snippet below)?
configure vlan FOO ipaddress 10.0.0.252/24
configure vlan FOO add secondary ipaddress 192.168.0.252/24
create vrrp vlan FOO vrid 1
configure vrrp vlan FOO vrid 1 add 10.0.0.254
configure vrrp vlan FOO vrid 1 add 192.168.0.254
2) Does it work with IPv6 addresses?
3) The examples show fabric routing setup with different priorities for the two routers/switches involved. What's the advantage of doing that? Is it just to define the master for direct pings?
Thank you (and Happy New Year!)
Frank
2 REPLIES 2
David_Choi
Hi Frank,
Yes, my customers use the secondary IP address and IPv6 in VRRP without any problem.
StephenW
Frank,
I don't see any reason why a secondary IPv4 or IPv6 wouldn't work. Different priorities just forces the master to be on one or the other instead of relying on the IP's. As a FYI the VRRP master is still responsible for answering all ARPs.
Stephen
