VRRP - separate VRIDs or single?
  • Question
  • Updated 3 years ago
  • Answered
Create Date: Feb 21 2013 9:35PM
Hi, I'm trying to optimize the implementation of VRRP on a pair of 480s at our network's core, and I'm wondering if the way it's set up now is optimal or not. Here's the current anonymized config (the switch has appropriate real IPs on each network):
create vrrp vlan client-net vrid 1
configure vrrp vlan client-net vrid 1 priority 90
configure vrrp vlan client-net vrid 1 authentication simplepassword pass1
create vrrp vlan client-net-2 vrid 20
configure vrrp vlan client-net-2 vrid 20 priority 90
configure vrrp vlan client-net-2 vrid 20 authentication simplepassword pass2
create vrrp vlan client-net-3 vrid 10
configure vrrp vlan client-net-3 vrid 10 priority 90
configure vrrp vlan client-net-3 vrid 10 authentication simplepassword pass3
configure vrrp vlan client-net vrid 1 add 192.168.1.1
configure vrrp vlan client-net-2 vrid 20 add 172.16.2.1
configure vrrp vlan client-net-3 vrid 10 add 10.200.150.1
enable vrrp vlan client-net vrid 1
enable vrrp vlan client-net-2 vrid 20
enable vrrp vlan client-net-3 vrid 10
What is best practice here? Should I roll all of the VRRP instances up into a single VRID, or keep them separate? These are networks we need to be resilient to failures and attacks - the separation of the VRIDs was intended to separate them so if one was knocked offline by a traffic storm or other problem the others would stay online, but I'm not sure that's a valid assumption. Any insight is appreciated. Thanks!
(from Ansley_Barnes)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Feb 25 2013 7:15PM
Hello Ansleybarnes
I am not sure using different VRIDs will give you what you want.  A VRID is used to designate a Virtual Router pair.  When any two routers have the same VRID it allows them to trade VRRP messages and provide redundancy for any VLAN that they have VRRP enabled on.
The best way I think to look at it is this.  If I have two routers and those two routers provide VRRP for x number of VLANs/subnets then they can share one VRID for all of the VLANs.  If I add two more routers and those routers provide VRRP to another set of x VLANs then I will use a separate VRID for those two routers so they know they can talk to one another.
If in your case you only have two routers you can use the same VRID whether or not the VRRP fails over is dependent on each VLAN so VLAN1 may fail over but VLAN2 may not depending on if you are using track or if a particular interface goes down.  One thing to note is that if you do have a split VRRP where one router is master for x number of VLANs and the second router is Master for another set of x VLANs and all VLANs need to route between then then you may need to have a routed segment between the two routers so that they can route to the other router.
I hope that is clear although some of this is a little hard to explain via txt.
Let me know if this helps or makes things worse and I will try to be more clear.
Thanks
P
(from Paul_Russo)
Create Date: Feb 27 2013 8:30PM
I think I got your meaning, prusso. The advice is appreciated. I'll put it on my list to consolidate these routers into a single VRID for simplicity's sake and evaluate if tracking is necessary to prompt individual failovers. In this particular instance it probably won't be necessary, but I'll see. Thanks again for the help.
Create Date: Mar 1 2013 9:50PM
Well, i just ran into this post after failing to create the 8th vrid on my BD8806:Error: Max number of virtual MACs reached, cannot use vrid 8 to create anotherSo it seems that using only one vrid for each virtual router pair is mandatory...This information should be added to the EXOS Concepts Manual, since I did'nt find anything there about vrid instances limit.Thanks.
(from Luis_Coelho)
Create Date: Mar 1 2013 10:05PM
Hello mrguga
There is a list of VRRP guidelines in the concepts guide on page 1103 for the 15_2 version.  Please see below.  I have highlighted the two that are based on this discussion.  In the first you can reuse the same number on the same router as many times as you want up to 128 interfaces (VLANs using VRRP) the part that says not on the same IP interface is when using Secondary IP addresses.  The main IP needs to be on one number like VRID1 and the other addresses need to be use a second number VRID2
The following guidelines apply to using VRRP:
● VRRP packets are encapsulated IP packets.
● The VRRP IPv4 multicast address is 224.0.0.18.
● The VRRP IPv6 multicast address is ff02::12.
● Duplicate VRIDs are allowed on the router but not on the same IP interface or VLAN.
● The maximum number of supported VRIDs per interface is seven.
● An interconnect link between VRRP routers should not be used, except when VRRP routers have
hosts directly attached.
● A maximum of 128 VRID instances are supported on the router.
● Up to seven unique VRIDs can be configured on the router. VRIDs can be re-used, but not on the
same interface
● VRRP and the Spanning Tree Protocol (STP) can be simultaneously enabled on the same switch.
● When VRRP and BOOTP/DHCP relay are both enabled on the switch, the relayed BOOTP agent IP
address is the actual switch IP address, not the virtual IP address.
● Extreme Networks does not recommend simultaneously enabling VRRP and ESRP on the same
switch.
● Do not configure VRRP and ESRP on the same VLAN or port. This configuration is not allowed or
supported.
Hope this helps.
P
(from Paul_Russo)
Photo of Ashish Sahu
Ashish Sahu
  • 340 Points 250 badge 2x thumb
Error: Max number of virtual MACs reached, cannot use vrid 4 to create another
Configuration failed on backup MSM, command execution aborted!
