VSS on Extreme BlackDiamond 8800 Series
  • Question
  • Updated 3 years ago
  • Answered
Now I have 2 of BD-8800-Series using in my Core-Network. And I need to bring 2 chassis into 1 virtual switch for manage only one switch (Like VSS on Cisco).
I read from another article I have to use MLAG with VRRP together right?
Anyone have a solution for BD-8800-Series to using virtual switch stacking?
And NetSight can do this?
Photo of PIYAPONG YWR
PIYAPONG YWR
  • 382 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
MLAG will allow you to have "port-channel, LAG etc.. " across multiple chassis without having them "bonded".  I am not familiar with the BD, but MLAG and VRRP might accomplish something similar, but you will be managing two chassis and a more complex config IMO.
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 6,168 Points 5k badge 2x thumb
Hi Piyapong,
Stacking is supported only in the Summit series switches not in BlackDiamond series switches but still you would be able to Achieve MLAG
here is the Knowledge article on the single tier MLAG.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-MLAG-in-Extreme-switches
Here is another article which have the steps to create VRRP active - active in a MLAG setup.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-VRRP-active-active-on-MLA...
Configuring MLAG would only make the two different switch ports to act as a single switches port and the switch management remains separate.
PIYAPONG YWR
Thank you.
I saw Extreme have ESRP. What's different about ESRP and VRRP. And can I try ESRP instead VRRP ?
And if anyone have an idea for single switch management, please advise to me.
Photo of Jeremy
Jeremy, Embassador
My advice is to use VRRP.  Its standards based and you’re going to find a lot more info on VRRP than ESRP.  From all the research I have done, VRRP would be the way to go, unless you need L2 redundancy.
PIYAPONG YWR
Thank you.
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,676 Points 10k badge 2x thumb
I'll go for MLAG and VRRP as well. Jeremy correctly stated that you'll still have to manage 2 separate Control Plane (config). 2 configs is obviously more than 1, but that's also more security. And, if correctly planned, both config should be very similar. Adding a new edge device into MLAG is just one line of config for MLAG, so not really a serious issue.
