VX9000 Cluster Management - Virtual IP
  • Question
  • Updated 2 months ago
  • Answered
Is there a way to configure a virtual IP for the active member of the wing controller cluster? I know this is normally achieved in a fashion similar to VRRP but I'm curious if someone manage to implement with the members in different subnets.
This is mainly so our guest administrators can login to the active controller in case of an issue. Also a nice indication of which controller is active.
Regards,
Bruno
Photo of Bruno Amarante
Bruno Amarante
  • 462 Points 250 badge 2x thumb
Posted 2 months ago
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 5,638 Points 5k badge 2x thumb
Hi Bruno,
VRRP - pretty much my words...
However, you'd need to create a common tunneled VLAN here so you do not face problem with different subnets.
Regards,
Ondrej
Bruno Amarante
Thanks Ondrej,
Didn't want to add extra complexity on the solution just to achieve this. Would be nice if there was a DNS option where the active just updates the record.
Good point!
My advice would be to contact your System Engineer and discuss a feature request so it could eventually make it to road plan for future WiNG releases!
Regards,
Ondrej
Bruno Amarante
Will do, thanks Ondrej
