VX9000e - Upgrade firmware from 5.8.6.5 to 5.9.0.0 - Wing Express cannot be updated to wing?
  • Problem
  • Updated 10 months ago
  • Solved
  • (Edited)
I cannot upgrade from VX9000E-5.8.6.5-002R.img to VX9000E-5.9.0.0-033R.img
I get the error: Wing Express cannot be upgraded to Wing?Thanks
Photo of Martin Sørensen
Martin Sørensen
  • 154 Points 100 badge 2x thumb
Posted 10 months ago
Photo of Alona
Alona, Employee
  • 1,660 Points 1k badge 2x thumb
This is known issue. We are working on a patch. Or you can instead do - upgrade to 5.8.6.0 and then to 5.9.0.0.
Martin Sørensen
Thanks, I cant find 5.8.6.0 in the Downloads page inside the Extreme Portal? Where can i find the 5.8.6.0 firmware? Thanks.
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Hello Alona, This is the great information. Could you create one article on our Extreme GTAC Knowledge?
Many thanks in advanced.
Bin
Photo of Christoph S.
Christoph S., Employee
  • 2,560 Points 2k badge 2x thumb
Hello Bin,
Please check out article WiNG Express device will not upgrade to newer code which addresses this issue.
Regards
Martin Sørensen
Thanks, cant find 5.8.6.0 in the Downloads page inside the Extreme Portal? Where can i find the 5.8.6.0 firmware? Thanks
Hello Martin,
Please contact our technical support team to create a case for same. We will be able to help you out with your request.
Regards,
Photo of Bin
Bin, Employee
Hello Christoph.
Thank you so much. The KCS article will be very useful reference.
Regards,
