VXLAN LAB testing on summit 670 G2 switches
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Hi
We are currently playing around with vxlan in a lab enviroment.
We have a ospf routed enviroment as seen in the diagram.
We are trying to extend a L2 vlan across the network from one pc to the next using VXLAN (VPLS replacement)
The config for the switch on the left is as follows:
configure virtual-network local-endpoint ipaddress 172.16.1.1 vr "VR-Default"
create virtual-network "VNET1" flooding standard
configure virtual-network "VNET1" vxlan vni 1
configure virtual-network "VNET1" add vlan tenant1
configure virtual-network "VNET1" monitor on
The config for the switch on the right is as follows
configure virtual-network local-endpoint ipaddress 172.16.1.4 vr "VR-Default"
If we run the following show commands it would seem that the vxlan link up and running:
Lefthand Switch:
show virtual-network vxlan vni 1
Created By : CLI Tenant VRF : VR-Default
Tenant VLAN : tenant1
Local Endpoint : 172.16.1.1 Endpoint VRF : VR-Default
Stats Monitor : On
Flooding : Standard
== VXLAN Information ==
VNI : 1 (0.0.1)
Group IP : Inner Tag : Exclude
Remote Endpoints : 172.16.1.4 (VR-Default)
== End VXLAN Information ==
Virtual Network Tenant VLAN
Encap ID Encap Flags
VNET1 tenant1
VXLAN 1 LRX
Encap Flags: (L) Local Endpoints Configured,
(R) Remote Endpoints Associated,
(X) Exclude Tag
Total number of Virtual Networks : 1
Local Endpoints : 172.16.1.1 (VR-Default)
Network Ports [VXLAN] : 1-64
Righthand Swith:
Local Endpoint : 172.16.1.4 Endpoint VRF : VR-Default
Stats Monitor : On
Flooding : Standard
VNI : 1 (0.0.1)
Remote Endpoints : 172.16.1.1 (VR-Default)
VNET1 tenant1
VXLAN 1 LRX
(X) Exclude Tag
Local Endpoints : 172.16.1.4 (VR-Default)
If we look at the FDB we see the locally connected device MAC learned in the Tenant Vlan but never the remote connected client.
It would seem that broadcast traffic (ARP) is not sent across.
Any ideas??
Photo of Andre Brits Kannemeyer
  • 5,020 Points 5k badge 2x thumb
Posted 2 years ago
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,592 Points 10k badge 2x thumb
Did you enable ospf vxlan extensions? If not you need to configure the remote vtep as well.
(Edited)
Hi Stephane, yes we have ospf vxlan extensions enabled. If you look at the above show virtual-networks output you will notice the remote peer is the opposite switch. This was automatically discovered via the ospf extensions
Indeed, LRX flag is good. Hard to read on a smartphone. You must be missing a basic thing on some other config. Jumbo frame maybe? Can you share ospf config on all routers?
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,782 Points 10k badge 2x thumb
according to the documentation it should suffice to statically configure the remote VTEPs if the OSPF VLAN extension is not used. Sadly I have no X670s available to test this.
Erik
  • 5,010 Points 5k badge 2x thumb
Hi Erik.... Lucky for me I have four 670's in my lab that needs configuration for a client, I am taking the opportunity to play before shipping the kit ;)
Photo of JS
JS, Employee
  • 630 Points 500 badge 2x thumb
hi,
maybe the following can help. [Single VXLAN Service-Single Tenant VLAN – Vlan ID 200 ]
JS
Thx Guys
Not sure what the exact problem was the config matched everything from JS's post... (I had MPLS with VPLS ect also running)
I factory reset all the switch, rebuilt the OSPF network and then added the VXLAN config and all is working.
Thx for the quick response
All working
So I think I found my previous problem.
On the middle two 670's we did not enable the OSPF VXLAN extension.
As soon as we did this we have full access.
The funny thing is that if we looked at the virtual network it did discover each other and everything looked fine.
Lessons learned:
Enable OSPF vxlan extentions on all switches in the OSPF Network.
If this is not supported by the Core OSPF devices, use static remote peers and not OSPF for vxlan discovery
Thx
(Edited)
That shouldn't be the case. What EXOS release are you using? Did you validate that when VPLS was also running or not?
Mmmm ok I have tested this again and you are correct I have disabled the OSPF VXLAN Ext on the core and it is still going.
Thx
Without OSPF VXLAN extensions the respective LSAs should still be generated and flooded as "Opaque LSAs". Thus the information needed for endpoint discovery should cross OSPF routers that do not know how to interpret them.
Andre, do you see the VXLAN related LSAs in the LSDB?
show ospf lsdb detail
If there is a problem with flooding those LSAs it would take some time for them to age out before you would see an effect after disabling the OSPX VXLAN feature on the middle switches. But creating new VXLANs should show the problem.
