Warn:BGP.RIBMgr.ProcStubMsgDataLost
  • Question
  • Updated 2 years ago
  • Answered
Hi Experts
What does the given error message mean? It shows up in logs.
An attempt to process an ATG_I3_INET_ADDR_IND has failed due to local
                                                             resource shortages or indication that the I3 join has lost some
                                                             information for the request
                                                             VR = 0x00000005
                                                             I3 join index = 1
                                                             Data lost flag value = 1
                                                             Local resource ret code = 0
Photo of Sumanta Ghosh
Sumanta Ghosh
  • 458 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Ron Huygens
Ron Huygens, Employee
  • 2,928 Points 2k badge 2x thumb
Hi Sumanta,
What EXOS version are you running?
This can caused by a buffer issue when you have lots of iBGP peers that send updates and exceed the maximum number of routes per message.
As far as I can see that should not really impact the normal traffic.
Sumanta Ghosh
Hardware is X770 and OS is 21.1.2.14.
There are hardly 30 BGP peers, spread cross in three VRs.
Then I suggest that you open a case for this. The issue reported should be investigated more thoroughly than what is possible on this forum.
Sumanta Ghosh
Hi Ron
Thanks, I have also noticed the below behavior during redundancy testing.
When Switch A reboots, traffic fails over to switch B. When Switch A recovers, after the reboot, all the i-BGP sessions drop and then re-establish on Switch B, causing communication loss for 2-5 minutes. When Switch B reboots, traffic fails over to switch A. When Switch B recovers after reboot, all the i-BGP sessions on switch A drop then re-establish on Switch A.
This happens every single time.
