We need a script to backup configuration of switch B5G124 FROM Inventory Manager using SCP protocol
  • 2
  • Question
  • Updated 1 year ago
  • Answered
We need a script to backup configuration of switch B5G124 FROM Inventory Manager using SCP protocol.
Photo of jose barrientos
jose barrientos
  • 92 Points 75 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,050 Points 5k badge 2x thumb
Jose,
It looks like you don't need a script for this. In Inventory Manager just right click on the device and select file transfer method. Select SCP.
jose barrientos
Hi Stephen,
Thanks for answer,
I selected SCP like transfer method,  but it no works
 but Inventory Manager shows me the following message
i have the following configuration  on " IMAGES INFORMATION" tab
Photo of Peter
Peter
  • 1,018 Points 1k badge 2x thumb
scp...on this position is wrong...because it describes the method of moving config from switch to netsight-server / inventory-manager.
When your Netsight-Sever is running on linux you need to create a cron-job using root-rights.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,226 Points 50k badge 2x thumb
In Netsight open the web help and search for "How to Set Up Third-Party Device Support".
There you'd find a description how to add a custom device definition file = script.
I've tried it myself but the new file wasn't visible in the pull down menu to select - not sure what I'm doing wrong - I've restarted Netsight & the client.
The part in the file for the config backup looks like below but as I've mentioned I wasn't able to test it so I'm not sure whether it's correct..
-----BEGIN SCRIPT "Configuration Upload"-----
delete configs/jcn3p.cfg
show config outfile configs/jcn3p.cfg
@receive 20
copy configs/jcn3p.cfg scp://%SCP_USER%:%SCP_PSWD%@%SCP_IP%/%TARGET_FILE_NAME%
exit
Photo of Tomasz Lubas
Tomasz Lubas
  • 534 Points 500 badge 2x thumb
Hello,
i had the same problem some times ago.
Working solution you can find below.
I've changed scp user and pass to scp. You should create scp user on netsight server.
/usr/local/Extreme_Networks/NetSight/appdata/InventoryMgr/properties/devicefiles
-- Use these scripts to manage Enterasys devices
name="B5 SCP Enterasys Networks"
desc="B5 SCP Enterasys Networks SSH/TFTP Scripts"
protocol=scp
-----BEGIN PRE-SCRIPT "Configuration Upload"-----
--   create /home/scp/b5-config.cfg
--   create absoluteFilePath2
-----END PRE-SCRIPT-----
delete configs/config-b5.cfg
@RECEIVE 5
show config outfile configs/config-b5.cfg
@RECEIVE 25
copy configs/config-b5.cfg scp://%SCP_USER%:%SCP_PSWD%@%SCP_IP%/%RELATIVE_TARGET_FILE_PATH%
@RECEIVE 25
exit
-----END SCRIPT-----
