Web Registration Issue in NAC
  • 2
  • Problem
  • Updated 2 years ago
  • Solved
Guest or BYOD user web registration is very slow or some times doesnt register at all any help pls..
Photo of Mir Ali
Mir Ali
  • 170 Points 100 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Stephen McGuire
Stephen McGuire
  • 1,012 Points 1k badge 2x thumb
I'm not sure if this is the same problem BUT it's a good place to start.  Verify the time on the NAC and your web controllers, make sure you have your SNTP set properly and there's no variation between all the devices.
Also look at this article: https://gtacknowledge.extremenetworks.com/articles/Solution/NAC-End-Systems-Hung-in-Captive-Portal
-Stephen
Photo of Brian Anderson
Brian Anderson
  • 626 Points 500 badge 2x thumb
Also, be sure that you have NAC ip addresses in the ip-helper addresses for the BYOD/guest vlan interface.
(Edited)
Photo of Mir Ali
Mir Ali
Thank you very much there was time difference between NAC and controller and i did correction hope this will solve this problem
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,854 Points 5k badge 2x thumb
I met similar issue with both EWC and NAC-GW (Identity Access Engine) sitting on the same vSwitch on the same VMware hosts. The communication from Qtrunk portgroup to non-qtrunkg portgroup was dropping packets heavily. this issue was fixed in new version of VMware.
good luck
