web-based authentication problem
  • Question
  • Updated 4 years ago
Create Date: Mar 4 2013 3:26AM
Now I want use web-based authentication.
Under firmware 12.6.x.x everything was ok(it will display netlogin screen) but when i use firmware 15.x.x.x it always display ScreenPlay screen,
Does any one can tell me what problem.
(from Hsu_LiPing)
Photo of EtherNation User
EtherNation User, Official Rep
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Mar 4 2013 5:38AM
have you tried to go back to 12.6 and find out if the problem is there or not (i.e, did the upgrade somehow changed something in the configs)? Also, can you post the output of the show conf netlogin here?
(from ethernet)
Create Date: Mar 4 2013 11:53PM
Following was my config partial infomation (for netlogin)
create vlan "Temp"
configure vlan Temp tag 1164
configure vlan Temp ipaddress 192.168.100.1 255.255.255.0
configure radius netlogin primary server x.x.x.x 1645 client-ip x.x.x.y vr VR-Default
configure radius netlogin primary shared-secret encrypted x.x.x.x
enable radius netlogin
configure netlogin vlan Temp
enable netlogin web-based
configure netlogin web-based authentication database-order radius
enable netlogin ports 13-18 web-based
configure netlogin base-url "network-access.itri.org.tw"
configure netlogin redirect-page "http://itriweb.itri.org.tw"
configure dns-client add name-server x.x.x.x vr VR-Default
configure dns-client add domain-suffix x.x.x.
enable sntp-client
configure vlan Temp dhcp-address-range 192.168.100.10 - 192.168.100.50
configure vlan Temp dhcp-options default-gateway 192.168.100.1
enable web http
(from Hsu_LiPing)
Create Date: Mar 7 2013 3:56AM
helpme, I have a free switch I can test this on. Let me find out what the result is. I will let you know.
(from ethernet)
