web-based authentication will fail os 15.x
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Mar 19 2013 7:08AM
Hi ethernet:
  At 3/2/2013 you posted you will test this function, can you tell me that result......
  Because my boss want use web-based authentication.
(from Hsu_LiPing)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Mar 19 2013 1:11PM
I saw the same behavior. I believe TAC is working on fixing this issue (as it turned out to be a bug). I am not sure when will the fix will be out. I will find out and let you know.
(from ethernet)
Create Date: Mar 20 2013 2:10PM
Yes, i can confirm, "netlogin Web-based" is not working.If i tried to connect a pc, send a http GET and the switch with Image XOS 15.3.1.4 replies with TCP-FIN, no HTTP-POST's.
(from Foxx)
Create Date: Mar 22 2013 6:42AM
If you try 15.2.3 or 15.1.3.4 patch 9, it is fixed in those versions of code.
(from ethernet)
