What algorithm is required in an Extreme Switch to connect an AP3825i with LACP enabled ?
  • Question
  • Updated 1 year ago
  • Answered
Good day.
What algorithm should be used in an Extreme Switch to configure Link aggregation and be able to connect an AP3825i with the LACP option enabled?
This is the command that has been used:
Enable sharing 1 grouping 22,23 address-based algorithm L2 lacp
The ports have the same VLAN, speed and duplex settings.
It is having problems signing this model to EWC and would like to discard the LAG.
I hope you can support me.
Greetings.
Photo of Jorge Cota
Jorge Cota
  • 440 Points 250 badge 2x thumb
Posted 1 year ago
Photo of faste
faste
  • 190 Points 100 badge 2x thumb
I belive there is a bug in 10.31. I've been running that conf. For about 2 years now but after 10.31 it stopped working.
Photo of Jorge Cota
Jorge Cota
That's the version I have in the EWC.
Then before 10.31 this model if you worked correctly with LACP ?.
Which version did you have previously?
Thank you Faste.
Photo of faste
faste
I've been using versions from 9.15.* via 9.21.*, 10.21.* and now 10.31.02 which looks like a very good release apart from some quarks.
Photo of Jorge Cota
Jorge Cota
Thanks for the support French, Luke.
In fact, it is the procedure that we are doing.
But by enabling the two ports on the Switch, which form a LAG, communication with the AP is lost.
Photo of Jorge Cota
Jorge Cota
Sorry faste.
So with version 10.31 you have the same problem?
We are considering lowering the EWC to version 10.21.
thanks for the support.
Photo of Joshua Puusep
Joshua Puusep
  • 2,274 Points 2k badge 2x thumb
just to confirm, are you trying to aggregate them to different switches or the same switch?
Photo of Jorge Cota
Jorge Cota
We are implementing Idenfiti on a campus, and the 3825i APs are causing us problems using LACP on various Switches (Standalone and Stacks).
Greetings.
Photo of Jorge Cota
Jorge Cota
The solution was to download the firmware to version 10.21.04.0005, later, the APs with LACP (3825i) worked correctly.
Greetings and thanks.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,502 Points 20k badge 2x thumb
