What does "n-strict — Click to enable the 802.11a mode of Radio 1 with 802.11n strict capability." mean?
  • Question
  • Updated 4 months ago
  • Answered
What does the "n-strict" mean in radio mode?
Does it mean only devices with an "n" radio can connect to the AP?
If your device an a/b/g then it won't connect?
"n" on 5GHz means up to 300 Mbps transmit rate per user?
"n" on 2.4GHz is up to 150 Mbps transmit rate between a user's device and the AP?
C5210 controller
APs are 3605/3610
Software: 09.21.10.0005
Photo of Laura
Laura
  • 1,490 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Ostrovsky, Yury
Ostrovsky, Yury, Employee
  • 3,050 Points 3k badge 2x thumb
That's correct , Laura . The AP will not advertise certain MCS rates so the legacy devices will not be able to connect. Although you need to be careful with this setting - the RF should be very clean and the device should be in good proximity to the AP to make it work stable.
Photo of Hartmut Sachse
Hartmut Sachse
  • 2,598 Points 2k badge 2x thumb
In the terminology "n-strict" enables the 802.11n Greenfield mode, like Yury told you this disable older data rates and only 802.11n PHY data rates are useable.
Photo of M.Nees
M.Nees, Embassador
  • 9,126 Points 5k badge 2x thumb
Thanks for answering this question!
Photo of SH
SH
  • 2,366 Points 2k badge 2x thumb
One additional hint. In the n-strict mode a frame header is used which older clients (= not 11n) can not understand. Therefore these clients see no wireless traffic but noise in the air.
Because of these clients can't read the preamble they do not know how long it takes to transmit the frame and simultaneous transmissions can happen.
