what is Extreme SSH default RSA KEY size?
  • Question
  • Updated 3 years ago
  • Answered
What is the Extreme SSH default RSA KEY size?
What commands to use?
Thank you so much for your response and any reply or attempt to help will be appreciated.
- Paul
Photo of Paul
Paul
  • 2,026 Points 2k badge 2x thumb
Posted 3 years ago
Photo of Taykin Izzet
Taykin Izzet , Employee
  • 2,924 Points 2k badge 2x thumb
Paul,
Is the key associated with SSH or SSL?  If the key is available, the top half of the key will display the key length. A Hex to ASCII converted can be used to get this information. A pregenerated key in EXOS shows a value of 2048 bit as shown below which would be default.
---- BEGIN SSH2 ENCRYPTED PRIVATE KEY ----
Subject: root
Comment: "2048-bit DSA key, root, Fri Jul 24 18:21:20 2015"
P2/56wAAA4IAAAAmZGwtbW9kcHtzaWdue2RzYS1uaXN0LXNoYTF9LGRoe3BsYWlufX0AAAAE
bm9uZQAAA0QAAANAAAAAAAAACACi4wAL/xGQRKGC+ZY02NEB8FKGKDI9/FG3WsyYU/tINalT
If SSL is enabled, the 'show ssl' command will provide the RSA key length in the output. The 'show sshd2 user-key' command may also provide some insight.
(Edited)
