What is the best firmware version for X670G2-48x-4q Switch?
Fabian_Padilla
We recently bought a summit X670G2-48x-4q Switch, but i don´t know if its actual firmware version ( 21.1.3.7) is the best firmware version or there is another firmware version that it is stable.
Best regards
Fabián Padilla Hernández
2 REPLIES 2
Alexandr_P
Valued Contributor
Hi!
You can check here - https://www.extremenetworks.com/support/compatibility-matrices/sw-release-extremexos-eos/
For X670G2-48x-4q most stable release is EXOS 16.2.4.5-patch1-8 or EXOS 21.1.5.2
Thank you!
Thanks for your reply Alexandr!!
