what is the best way to reboot an entire stack of 3 switches?
  • Question
  • Updated 2 years ago
  • Answered
I'm assuming that reboot stack-topology will reboot all 3 switches in the stack and have them come back up without changing slots.
Is this true or is there some other way that I should reboot them?
Photo of Stanley Riley Jr.
Stanley Riley Jr.
  • 950 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Darren Saliva
Darren Saliva
  • 662 Points 500 badge 2x thumb
I usually just use the reboot command without specifying a slot and the entire stack reboots.
Stanley Riley Jr.
Thanks Darren.  I have a tendency to overthink these things sometimes.  :)
Photo of Andrew Imam
Andrew Imam, Alum
  • 1,026 Points 1k badge 2x thumb
The reboot stack-topology when issued from the stack master node should also reboot the entire stack.
Stanley Riley Jr.
Thank you as well Andrew!
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,834 Points 5k badge 2x thumb
If you reboot a stack or stack member, the unit numbering will not chamge.
Photo of Santhosh Durai
Santhosh Durai, Employee
  • 110 Points 100 badge 2x thumb
reboot stack-topology command is used to reboot the entire stack. difference between reboot and reboot stack-topology is, "reboot stack-topology" command can be executed from any slot.  but reboot command can be executed only from master node.
Photo of Henrique
Henrique, Employee
  • 10,342 Points 10k badge 2x thumb
There are 2 different purposes/concepts for "reboot" and "reboot stack-topology" commands.
When you use "reboot" command on master node it will reboot all units in the Active Topology. That means only stacking members working and running will be rebooted.
However, if you do "reboot stack-topology", it will reboot the Stack Topology regardless of its members state.
