What is the default management IP of an X460-24t switch?
  • Question
  • Updated 6 days ago
  • Answered
Photo of Joel Garcia
Joel Garcia
  • 212 Points 100 badge 2x thumb
Posted 3 weeks ago
Photo of Drew C.
Drew C., Community Manager
  • 40,688 Points 20k badge 2x thumb
Hi Joel,
There isn't a default IP address on the management VLAN/port. However, depending on the software version, the switch will get an IP address via DHCP and will flash the address in the LED panel used to display stacking slot number.
Photo of Tomasz
Tomasz
  • 2,316 Points 2k badge 2x thumb
Hi Drew,
In the past, when ZTP (not ZTP+) was first introduced (16.1 AFAIR), there also was a thing that allowed an EXOS switch to assign an APIPA on his own if no DHCP offer was given, and that IP was in form of 169.254.xx.yy, where the last two octets are the last two octets from the switch's MAC address. Is it still there?
Kind regards,
Tomasz
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,676 Points 10k badge 2x thumb
On a G1, there's no default IP. With 21.1+, so G2 and newer switches, a default config switch would try DHCP and if it fails, it would have the link layer IPv4 address, based on the MAC: that would be displayed digit by digit on the LED panel for the stacking slot number (as Drew said).
Joel Garcia
Thank you very much for your help guys, I still haven't been able to access the switch, I'm trying to access via console but I haven't been able either.
For more details I'm using the following configuration in PuTTy
Speed: 9600
Data bits: 8
Stop bits: 1
Parity: None
Flow control: XON/XOFF
Photo of Tomasz
Tomasz
What cables are you using?
Straight-through or crossover RJ45? Then Extreme RJ45/DB9 adapter + DB9/USB adapter?
Regards,
Tomasz
(Edited)
Joel Garcia
I'm using RJ45 crossover. Then Extreme RJ45/DB9 adapter + DB9/USB adapter
(Edited)
Photo of Drew C.
The cable in the bag is a straight cable. Is that the one you're using?
(Edited)
Joel Garcia
in the image above you share the kit I'm using
