What is the difference between RSTP and rate limit on switch port
  • Question
  • Updated 1 year ago
  • Answered
Implemented rate limit and RSTP solution to protect network from loop but it didnt help
Photo of waqas
waqas
  • 350 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
You need to turn on edge safeguard, or admin edge depending on the variety of switch and OS.
Photo of Jeremy
Jeremy, Embassador
This is good to apply to edge ports (non-uplink).
    configure stpd s0 ports link-type edge 1:1-48 edge-safeguard enable bpdu-restrict
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,486 Points 10k badge 2x thumb
RSTP is a layer 2 redundancy protocol used to block redundant links (preventing a loop), and rate-limit is a switch functionality to limit the amount of traffic that can be transmitted. They aren't really directly comparable, although they can both impact the presence of a loop and the switches behavior during a loop.
Like Jeremy mentioned earlier, if you want to use RSTP to prevent loops on edge ports, you would need to use edge-safeguard/bpdu-restrict (or another comparable STP extension feature on other platforms).
