What is the minimum PSU requirement for BD8810 with total of 7 slot occupied
  • Question
  • Updated 2 years ago
  • Answered
Hi all,
I am planning to use BD8810 in our network and I could not decide "What is the minimum PSU requirement for BD8810" where as only 7 slot will be used in phase 1 including 2 MSM. I guess 6 PSU is for full load.
Thanks
Photo of Tayzar Lwin
Tayzar Lwin
  • 238 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,288 Points 3k badge 2x thumb
Tayzar,
The "show power budget" command would let you know the Black Diamond chassis power redundancy requirements.
Photo of Roy Noh
Roy Noh, Employee
  • 1,442 Points 1k badge 2x thumb
It will depend on which I/O cards inserted on it.
Can you specify all of them? Are you going to use PoE also?
Photo of Ariyakudi Srinivas, Muthuraman
Ariyakudi Srinivas, Muthuraman, Employee
  • 994 Points 500 badge 2x thumb
Hi Tayzar,
To add on, there are few different power rated PSU's available for the chassis.
So it would all depend on the PSU rating you are using in the chassis. As my colleague has provided a command in the previous update, it would help you determine the power used and available power in redundancy.
There are quite a few caveats you need to consider on this and the Extreme Networks BlackDiamond 8800 Series Switch Hardware Installation Guide gives you good insight into you request.
http://documentation.extremenetworks.com/blackdiamond8800/downloads/8000_Series_Hardware_Install_Gui...
Thanks,
Hi Tayzar,
As suggested by my colleagues, we could determine how much power each module requires could be checked using "show power budget". A sample snapshot:-
Photo of Roy Noh
Roy Noh, Employee
The above command is great if you already have a BD8K.
But if you don't have it now, you can calculate it with the power specification on data sheet.
Also I have a excel file to calculate the number of PSU needed for your installation with/without PSU redundancy.
If you think it can be helpful, leave a email address and I will send it to you.
Tayzar Lwin
Thanks all for your helpful replies. Actually the device is not in hand yet. I am creating BOM and curios about how many PSU to order. No PoE will be used. I just want to know what is the minimum required PSU to run BD8810. Now I think I could estimate it.
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
Please find below the link to let you know the minimum requirements for PSU related to BD series:
http://documentation.extremenetworks.com/blackdiamond8800/BlackDiamond/8800_Install_Guide/c_power_su...
Tayzar we hope you got the response which you were looking for. If so  then let us close this Hub thread.
Wish  you in advance happy new year 2017 ..........
