What summit switch would be good to use for practice?
  • Question
  • Updated 2 years ago
  • Answered
I like using virtual EXOS and all, but I'm aware there's some functionality that just can't be emulated in a VM (same is true for VMs from other vendors, too).  I was looking around on ebay, considering getting 2-3 summit switches to add to my practice lab, and wasn't sure which model would be the closest equivalent to what I can run in my EXOS VMs.
I'm also guessing I'd have to get licenses to enable all the functionality on the physical switches, correct?
Photo of Deadpool
Deadpool
  • 380 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Rebecca Franco
Rebecca Franco, Employee
  • 270 Points 250 badge 2x thumb
You can enable a trial license to practice with once you obtain some switches. Below is a link to an article with the procedure. The trial license is valid for 30 days.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-enable-trial-license
Photo of Deadpool
Deadpool
Thank you.  :)
Photo of Chad Smith
Chad Smith, Alum
  • 5,640 Points 5k badge 2x thumb
Andrew,
As for which models to purchase, it really depends on what you want to do.  Are there particular features or functionality you want to test?
You want to avoid the legacy ExtremeWare gear as those products do not run EXOS.  Those products would be Alpine, BD6800 and generally any Summit that ends in '00' (i.e Summit 200, 300, 400) or  'i' (i.e Summit 48si)
Photo of EtherMAN
EtherMAN, Embassador
  • 6,648 Points 5k badge 2x thumb
Summit 440 ... summit 250 ... summit 450.... First one is current summit switch that will have more layer 3 functions.  Next two are older models that still have some layer 3 functions to play with.  Last one is also an older model that would have a bit more horsepower.  Other than enabling the demo full licenses on these you will need to discuss with GTAC on whither you can update to newer code and how current you can get....
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,254 Points 10k badge 2x thumb
One thing to note on the X440 and X250 is that these do not support features included in the core license. While the trial license that Rebecca suggested will allow these features to be configured, they may not behave correctly as the switch does not have hardware support for some features.
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
As already mentioned by Chad, it depends on which features are you planning to test.
You can check both links below for License information and which License is used by switch model (you can navigate using the left menu when using these links for more details):
Licenses based on platform:
http://documentation.extremenetworks.com/FLR/EXOS_All/Feature_License_Requirements/r_overview.shtml#...
Core License Features:
http://documentation.extremenetworks.com/FLR/EXOS_All/Feature_License_Requirements/r_core-license-fe...
Photo of Deadpool
Deadpool
Terrific!  Thanks folks  :)
